How to enable seconds in system clock
2023-02-02T20:46:44+00:00
Title says it all.
Found this article, which had a couple suggestions: https://winaero.com/how-to-enable-seconds-for-the-taskbar-clock-in-windows-11/
" Settings > Personalization > Taskbar > Taskbar behaviors, and check the “Show seconds in system tray clock” option."
Is not there for me
Tried registry fixes, but that made it worse and actually removed the system clock all together, while also breaking the start menu completely. Had to undo that change and now back to square one.
Why on Earth would Microsoft remove the seconds from the clock? I use it quite often for a game I play.. Very frustrating when they remove common sense features like this. Really looks like MSoft put some extremely incompetent people in charge of Win 11. Reminds me of when they hired the guy from Nike to design Win 8 Metro UI. I think we all remember how that went!!
EDIT: WAS fixed for about 2 months with April update, but now it's gone again!!!
Someone from Microsoft owes me an explanation!!
2023-04-29T09:12:23+00:00
Fix in latest stable update from April (then one bot on Path Tuesday, but later).
68 additional answers
    2023-02-02T22:11:17+00:00
    I understand your frustration, I am also a user of Windows 11 like you are, I am not a Microsoft employee I am an independent advisor, and windows 11 being a new window it will take some time for it to have all the features that one may need.
    I would suggest submitting feedback to the support engineer team of Microsoft so that they can add the features that you have talked about in future releases.
    https://feedbackportal.microsoft.com/feedback
    Kind regards
    Mustafa
  2. EmilyS_726 29,570 Reputation points Volunteer Moderator
    2023-02-08T01:38:30+00:00
    Hello brianp89, this is Emily.
    The Windows 11 build quoted in the article is the Insider version. You can read about it from Microsoft's Insider blog here: https://blogs.windows.com/windows-insider/2022/11/18/announcing-windows-11-insider-preview-build-25247/  It does mention the feature to display second for time.
    You won't get insider version of Windows via regular update. You need to be in the Insider program in order to get these preview builds. I wouldn't recommend switching to Insider version just for this feature, especially when it is still in Dev channel, there can be rough edges and it is not stable.
    You can continue to use the Insider blog to stay updated on these new development, and hopefully that feature will be available to the production version soon.
    2023-04-12T00:07:17+00:00
    Let's be real, and honest here. Windows 11 is NOT NEW.
    That excuse will just not work.
    2023-04-12T13:15:19+00:00
    Cannot believe it STILL hasn't been added after many feature requests submitted.. They don't care/listen. Windows 11 is a huge insult to advanced users. Massive step in the wrong direction.
