Fix in latest stable update from April (then one bot on Path Tuesday, but later).
How to enable seconds in system clock
Title says it all.
Found this article, which had a couple suggestions: https://winaero.com/how-to-enable-seconds-for-the-taskbar-clock-in-windows-11/
" Settings > Personalization > Taskbar > Taskbar behaviors, and check the “Show seconds in system tray clock” option."
Is not there for me
Tried registry fixes, but that made it worse and actually removed the system clock all together, while also breaking the start menu completely. Had to undo that change and now back to square one.
Why on Earth would Microsoft remove the seconds from the clock? I use it quite often for a game I play.. Very frustrating when they remove common sense features like this. Really looks like MSoft put some extremely incompetent people in charge of Win 11. Reminds me of when they hired the guy from Nike to design Win 8 Metro UI. I think we all remember how that went!!
EDIT: WAS fixed for about 2 months with April update, but now it's gone again!!!
Someone from Microsoft owes me an explanation!!
68 additional answers
2025-04-22T02:15:40+00:00 I only want a time clock.
2025-04-24T18:03:23+00:00 This worked for me. Thank you so much!
2025-04-24T23:51:39+00:00 Although many people have been saying to look under
Settings -> Time & language -> Date & time
to find the relevant setting, I did not find it there.
Where I *did* find it - on Windows 11 24H2 - was under Settings -> Personalization -> Taskbar -> Taskbar behaviors. There was a checkbox there for "Show seconds in system tray clock (uses more power)".
I was also able to get seconds to show up by editing the "Short time" value in the "Additional settings..." sub-dialog of the dialog presented by invoking 'intl.cpl' (which can also be accessed by opening the old Control Panel and clicking the "Region" applet), logging out, and logging back in. I suspect that what the "Show seconds in system tray clock" toggle does is tell Windows to use the "Long time" format string rather than the "Short time" one.
2025-04-28T16:22:23+00:00 As of 2025-04-28 if you search for 'seconds' in settings it can be found under Time & Language > Date & Time as an option under the Show time and date in the System tray.
