Memory Management and Unexpected Store Exception stop code
2023-03-28T06:28:52+00:00
Please help, my computer keep crashing while i'm on a game or crashing randomly and cause a bsod "Memory_Management" and "Unexpected_Store_Exception".
I tested my RAM using Memtest and my Harddisk using chkdsk and check the health with crystaldiskinfo, and not a single error occured. All of my hardware driver is up to date
Source
Windows
Summary
Shut down unexpectedly
Date
‎3/‎27/‎2023 5:50 AM
Status
Report sent
Problem signature
Problem Event Name: BlueScreen
Code: 1a
Parameter 1: 3f
Parameter 2: 36b39
Parameter 3: ffffff7c
Parameter 4: c35bc958
OS version: 10_0_22621
Service Pack: 0_0
Product: 256_1
OS Version: 10.0.22621.2.0.0.256.48
Locale ID: 1033
Extra information about the problem
Bucket ID: PAGE_HASH_ERRORS_0x1a_3f
Source
Windows
Summary
Date
‎3/‎28/‎2023 1:19 PM
Status
Report sent
Problem signature
Code: 154
Parameter 1: ffffe5058fde4000
Parameter 2: fffffd8fefb65f20
Parameter 3: 2
Parameter 4: 0
Service Pack: 0_0
Product: 256_1
Locale ID: 1033
Bucket ID: 0x154_c0000006_c0000483_IMAGE_storahci.sys
2023-04-04T02:40:27+00:00
  1. After completing the chkdsk switches (chkdsk /b /v) please backup all important files on the Seatools disk drive.
(save files to another disk drive or the cloud)
The ST1000DM010-2EP102 drive has multiple bad blocks.
It is best to replace a disk drive with many bad blocks or a disk drive with increasing bad blocks.
A disk drive can be used until the terminal event as long a the computer user can tolerate:
a) slow read
b) slow write
c) hangs and freezes
d) BSOD and unexpected shutdowns and restarts
etc.
  1. Run the Crucial scanner to view disk drive replacement options.
Crucial System Scanner | Memory Upgrade Scanner | Crucial | Crucial.com
  1. After backing up files plan to disconnect the D: drive and monitor the computer for stability / instability.
  2. Monitor the computer stability / instability using Reliability Monitor:
Reliability Monitor is the Best Windows Troubleshooting Tool You Aren’t Using (howtogeek.com)
  1. For any BSOD after detaching the D: disk drive:
a) post an new V2 share link into the newest post
b) plan to run Memtest86 overnight (two tests of four passes each for a total of eight passes)
MemTest86 - Official Site of the x86 and ARM Memory Testing Tool
49 additional answers
    2023-03-29T09:58:56+00:00
    What should i do?
  2. DaveM121 934.5K Reputation points Independent Advisor
    2023-03-29T10:00:48+00:00
    Hi Rexy Kurniawan,
    To try to force Windows 11 show any faulting drivers, the best option would be to turn on Driver Verifier, let your PC crash 3 times, then you must turn off Driver Verifier, and finally, upload any newly created minidump files
    https://answers.microsoft.com/en-us/windows/for...
    Note, if you have any difficulty getting into Windows with Driver Verifier enabled:
    Start your PC, just as Windows attempts to load (spinning dots), press and hold Power Button for 5 - 10 seconds to perform a Hard Shut Down
    Do this twice
    On the third start Windows will boot into the Recovery Environment and from there you can access System Repair, Safe Mode, Command Prompt... etc.
    Go to Troubleshoot - Advanced Option - Startup Settings and click Restart
    Upon restart, press 4 to enter Safe Mode
    Open Command Prompt as Administrator and run these two commands, then restart your PC.
    verifier /reset
    verifier /bootmode resetonbootfail
    2023-03-29T10:15:43+00:00
    Here's the minidump: 032923-11343-01.rar
  4. DaveM121 934.5K Reputation points Independent Advisor
    2023-03-29T10:20:57+00:00
    Hi Rexy Kurniawan,
    Please ensure you have disabled driver verifier.
    That minidump file is listing the crypt driver in Windows, do you have your hard drive encrypted?
