Memory Management and Unexpected Store Exception stop code
2023-03-28T06:28:52+00:00
Please help, my computer keep crashing while i'm on a game or crashing randomly and cause a bsod "Memory_Management" and "Unexpected_Store_Exception".
I tested my RAM using Memtest and my Harddisk using chkdsk and check the health with crystaldiskinfo, and not a single error occured. All of my hardware driver is up to date
Source
Windows
Summary
Shut down unexpectedly
Date
‎3/‎27/‎2023 5:50 AM
Status
Report sent
Problem signature
Problem Event Name: BlueScreen
Code: 1a
Parameter 1: 3f
Parameter 2: 36b39
Parameter 3: ffffff7c
Parameter 4: c35bc958
OS version: 10_0_22621
Service Pack: 0_0
Product: 256_1
OS Version: 10.0.22621.2.0.0.256.48
Locale ID: 1033
Extra information about the problem
Bucket ID: PAGE_HASH_ERRORS_0x1a_3f
Source
Windows
Summary
Date
‎3/‎28/‎2023 1:19 PM
Status
Report sent
Problem signature
Code: 154
Parameter 1: ffffe5058fde4000
Parameter 2: fffffd8fefb65f20
Parameter 3: 2
Parameter 4: 0
Service Pack: 0_0
Product: 256_1
Locale ID: 1033
Bucket ID: 0x154_c0000006_c0000483_IMAGE_storahci.sys
2023-04-04T02:40:27+00:00
  1. After completing the chkdsk switches (chkdsk /b /v) please backup all important files on the Seatools disk drive.
(save files to another disk drive or the cloud)
The ST1000DM010-2EP102 drive has multiple bad blocks.
It is best to replace a disk drive with many bad blocks or a disk drive with increasing bad blocks.
A disk drive can be used until the terminal event as long a the computer user can tolerate:
a) slow read
b) slow write
c) hangs and freezes
d) BSOD and unexpected shutdowns and restarts
etc.
  1. Run the Crucial scanner to view disk drive replacement options.
Crucial System Scanner | Memory Upgrade Scanner | Crucial | Crucial.com
  1. After backing up files plan to disconnect the D: drive and monitor the computer for stability / instability.
  2. Monitor the computer stability / instability using Reliability Monitor:
Reliability Monitor is the Best Windows Troubleshooting Tool You Aren’t Using (howtogeek.com)
  1. For any BSOD after detaching the D: disk drive:
a) post an new V2 share link into the newest post
b) plan to run Memtest86 overnight (two tests of four passes each for a total of eight passes)
MemTest86 - Official Site of the x86 and ARM Memory Testing Tool
49 additional answers
    2023-03-28T12:38:03+00:00
    Somehow my RAM pass the scan, i will test it again later
  2. DaveM121 934.2K Reputation points Independent Advisor
    2023-03-28T12:38:46+00:00
    Ok Rexy Kurniawan, please let me know the result of that.
    2023-03-28T15:02:11+00:00
    The result is my RAM is in a good condition
  4. DaveM121 934.2K Reputation points Independent Advisor
    2023-03-28T15:04:04+00:00
    Hi Rexy Kurniawan,
    Thank you for that information, if your system continues to crash, please upload any newly created minidump files.
