The original problems have been fixed, no need to turn off prioritization engine anymore. 😉
Win 10 Pro 22H2, Ethernet upload speed slow, Wireless and Ethernet in safe mode just fine
My Win 10 machine has upload speeds under 1Mbps when using an Ethernet connection. Wireless upload speed is 15-20Mbps. Safe mode Etnernet connection is also 15-20Mbps. Here's what I've tried:
- Install latest network card driver
- Run the network troubleshooter - no problems found
- Followed the netsh and ipconfig commands at https://answers.microsoft.com/en-us/windows/forum/all/upload-speed-is-slow-only-on-win-10/fd9c7c38-c84d-4791-a77d-c480fea05875
- Reset connections via Start > Settings > Network & Internet > Status > Network reset
Any other ideas?
2024-03-11T01:42:04+00:00 -
2024-03-11T02:09:47+00:00 Thanks very much for the help.
Actually, for whatever reason on my System, turning off the prioritization engine did work! Full bandwidth now restored on uploads! What a relief!
2024-03-11T02:24:19+00:00 Thanks very much for the help.
Yes, it worked when they had the bug, now it looks like the problem is fixed with latest versions.
The same problem was also with Windows 11.
No need to turn off prioritization anymore.
Works fine for me leaving it on. 👍
