thx.i will try that.slow the uploading speed also cost hard to log in some website.specially with webpage has lots of loading.sometimes cant even load the image,or always on the loading.i also bought Macfee thought it may because of virus or something
Win 10 Pro 22H2, Ethernet upload speed slow, Wireless and Ethernet in safe mode just fine
My Win 10 machine has upload speeds under 1Mbps when using an Ethernet connection. Wireless upload speed is 15-20Mbps. Safe mode Etnernet connection is also 15-20Mbps. Here's what I've tried:
- Install latest network card driver
- Run the network troubleshooter - no problems found
- Followed the netsh and ipconfig commands at https://answers.microsoft.com/en-us/windows/forum/all/upload-speed-is-slow-only-on-win-10/fd9c7c38-c84d-4791-a77d-c480fea05875
- Reset connections via Start > Settings > Network & Internet > Status > Network reset
Any other ideas?
2024-01-28T07:57:41+00:00 -
2024-03-10T20:20:27+00:00 Hi Steve,
Just saw your post..I have the same problem as you describe. How did you turn off the Killer Prioritization Engine?
2024-03-10T20:44:31+00:00 I set all of the Killer* services to startup type = disabled. That's been working reliably for a few months.
2024-03-10T21:30:37+00:00 Glad that works. I upgraded it a couple of times and was able to turn off the prioritization engine, and then one day it turned back on. Couldn't figure out how to delete it so stopping the services worked. I don't trust the software to not turn back on.
