Win 10 Pro 22H2, Ethernet upload speed slow, Wireless and Ethernet in safe mode just fine
2023-02-03T04:01:46+00:00
My Win 10 machine has upload speeds under 1Mbps when using an Ethernet connection. Wireless upload speed is 15-20Mbps. Safe mode Etnernet connection is also 15-20Mbps. Here's what I've tried:
Any other ideas?
    2023-03-07T00:10:30+00:00
    So far so good. Nothing else has worked to permanently fix this issue.
    2023-03-07T00:25:19+00:00
    My desktop has been fine since i turned off the Killer Prioritization Engine, not 1 hitch, but it sure doesnt say much for microsoft, Dell, and the oweners of KIller software does it.
    2023-03-08T16:34:04+00:00
    Interesting. I recently serviced a customers Dell with a similar problem - very slow Internet except in Safe Mode. The culprit was "SmartByte Drivers and Services" a similar piece of junk software pre-installed by Dell (that is ostensibly intended to optimize streaming video).
    Maybe our info will help others running into this problem.
    2023-03-13T18:34:42+00:00
    Intel drivers are bugged out ...
    Go to your Killer app panel : disable the prioritization engine feature, switch it off and retest you'll see ...
    On my computer the features is useless since 6 months ago i think it is a bug ...
    or it is a feature : old drivers at launch were perfectly fined ...
    Intel(inside) ...
    You are welcome ...
    Iam not a MVT professional, just a hacker who knows IT ...
    2023-03-19T22:05:53+00:00
    Has anybody had luck with uninstalling the Killer software and having your upload speed not decrease? When I uninstall it, my upload speed drops to less than 1Mb.
