Pls try this:
Re-enable only this audit policy.
Delete the Auditpol.exe scheduled task.
That should do the trick.
My aim is to log the events when service "Log On As" property has been changed. I am trying to find out who changed this property, the name of service and the new value of property.
Undo the settings shown in the screenshot and try this:
Run:
auditpol /set /subcategory:"Registry" /success:enable
And then open Regedit.exe and go to:
HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Services
Right-click "Services" → Permissions
Click Advanced.
Select "Auditing"
Click "Add"
Add "Everyone".
Expand special permissions and enable "Set value" (and perhaps "Delete"). Uncheck all other boxes.
Click OK, OK, OK to close all dialogs.
If the other user is going to change the service configuration using SC.exe or Services MMC, the user name will be shown as SYSTEM, because it's the service controller that powers the operation.
Unless the user changes the setting directly in the registry, event logs can't capture the user name who did the change.
What you can do is attach an event trigger to the event 4657 and write a script that will parse the last event 4657 and also write the currently logged-on user name. The script can output the event to a custom event log or a file.
Here's a sample VBScript you can attach as an event trigger to 4657.
Set objNetwork = CreateObject("Wscript.Network")
Set WshShell = CreateObject("WScript.Shell")
sCmd = """" & "The current user is " & objNetwork.UserName & " - " & now & """"
sCmd = "cmd.exe /c echo " & sCmd & " >>c:\windows\temp\events.log"
WshShell.run sCmd, 0
sCmd = "cmd.exe /c wevtutil qe " & """" & "Security" & """" & _
" /q:" & """" & "*[System[(EventID=4657)]]" & """" & " /c:1 /f:text /rd:true >>c:\windows\temp\events.log"
It's a crude script without any error handling or anything. I posted it for demostration purposes. However, you can add the necessary features to it easily.
When a user changes the service configuration, event 4657 is logged, triggering the above VBScript file. The VBS logs the entry to C:\Windows\Temp\Events.log by appending the file.
Here's a sample event logged into the Events.log file:
"The current user is ramesh - 2/25/2023 11:23:29 PM"
Event[0]:
Log Name: Security
Source: Microsoft-Windows-Security-Auditing
Date: 2023-02-25T23:23:28.0300000Z
Event ID: 4657
Task: Registry
Level: Information
Opcode: Info
Keyword: Audit Success
User: N/A
User Name: N/A
Computer: OptiPlex-9020
Description:
A registry value was modified.
Subject:
Security ID: S-1-5-21-1792754669***********
Account Name: ramesh
Account Domain: OPTIPLEX-9020
Logon ID: 0x8AEF9B0
Object:
Object Name: \REGISTRY\MACHINE\SYSTEM\ControlSet001\Services\AdobeFlashPlayerUpdateSvc
Object Value Name: ObjectName
Handle ID: 0x3cc
Operation Type: Existing registry value modified
Process Information:
Process ID: 0x1038
Process Name: C:\Windows\regedit.exe
Change Information:
Old Value Type: REG_SZ
Old Value: sdf
New Value Type: REG_SZ
New Value: LocalSystem
Sample event #2
"The current user is ramesh - 2/25/2023 11:32:30 PM"
Event[0]:
Log Name: Security
Date: 2023-02-25T23:32:29.7150000Z
Event ID: 4657
Task: Registry
Level: Information
Opcode: Info
User: N/A
User Name: N/A
Description:
Subject:
Security ID: S-1-5-18
Account Name: OPTIPLEX-9020$
Account Domain: WORKGROUP
Logon ID: 0x3E7
Object:
Handle ID: 0x88c
Process ID: 0x398
Process Name: C:\Windows\System32\services.exe
Change Information:
Old Value: s
I hope that fits the bill perfectly. Let me know.
Hi Dear,
thanks for update,
I think you have already trying, just confirm
In the Event Viewer, "Windows Logs" in the left pane, and then select "Security" from the sub-menu.
In the right pane, you can click on the "Filter Current Log" option under the "Actions" menu.
In the "Event ID" field, type "4657" (which is the event ID for changes to object permissions) and click on the "OK" button.
Now, the log will display only the events related to changes in object permissions. To further filter the events based on your requirements, click on the "XML" tab at the bottom of the window.
In the XML tab, click on the "Edit" button, and then paste the following XML query:
<QueryList>
<Query Id="0" Path="Security">
<Select Path="Security">
\*[System[(EventID='4657')]]
and
\*[EventData[Data[@Name='ObjectName'] and (Data='SERVICE\_NAME')]]
and
\*[EventData[Data[@Name='Properties'] and (contains(Data,'SeChangeNotifyPrivilege'))]]
</Select>
</Query>
</QueryList>
Replace "SERVICE_NAME" with the actual name of the service you want to monitor.
Click on the "OK" button to apply the filter.
Now, the log will display only the events related to changes in the "Log On As" property of the specified service. You can view the details of each event to see who changed the property, the name of the service, and the new value of the property.
EDIT:
Based on your updated information, it seems like you're looking for a more detailed and granular level of auditing for the specific service properties that are being changed.
n this case, I recommend you to use a third-party auditing tool that provides more advanced auditing capabilities.
One such tool is the Netwrix Auditor for Windows Services, which allows you to audit all changes to the Windows services, including changes to service accounts, service dependencies, and service startup types. The tool provides detailed audit trails that capture who made the change, when it was made, and what was changed, and it can generate reports that help you quickly identify and investigate any suspicious changes to the services.
Another option is to use PowerShell scripts to monitor and audit changes to the specific service properties that you're interested in. For example, you can use the Get-Service cmdlet to retrieve the current properties of the service, and then use the Set-Service cmdlet to set the auditing options for the specific properties that you want to monitor. You can also use the EventLog class in PowerShell to create custom event logs and write entries to the logs when specific events occur.
I think not will solve for you, but don't afraid, I can route to another experts help us!
Kind Regards,
R. Cord
R. Cord here, Independent Expert. Hope you are doing well.
You can monitor services for changes in specific properties using Windows Event Viewer. Here are the steps to do so:
Open the Event Viewer by typing "Event Viewer" in the Windows search bar and selecting it from the results.
In the left-hand pane, navigate to "Windows Logs" > "Security".
In the right-hand pane, click on "Filter Current Log..." and enter the following filter criteria:
Event ID: 4672 (this is the event ID for an audit event generated when a privileged service is started or stopped)
Task Category: "Special Logon" (this narrows down the search to events related to privileged logons)
Click on "OK" to apply the filter.
Look for events with the description "Special privileges assigned to new logon" and with the following details:
Subject: This will show you the user account that initiated the change.
Object: This will show you the name of the service and the new value of the "Log On As" property.
Process Information: This will show you the process that was used to make the change.
By reviewing these events, you should be able to determine who changed the "Log On As" property for a specific service, the name of the service, and the new value of the property. Note that auditing needs to be enabled for these events to be logged, so you may need to enable auditing on your system if it's not already enabled.
Based on the screenshots you provided, sounds that you are trying to access the Winlogbeat service on Windows it seems that the Security tab is not visible or available for this service.
Check:
Insufficient permissions: You may not have sufficient permissions to view the Security tab for the service. Try logging in as an administrator or a user with administrative privileges to see if that resolves the issue.
Group Policy settings: It is possible that the Security tab has been disabled through Group Policy settings on the computer or domain. You can check the Group Policy settings to see if this is the case and modify them accordingly.
Service configuration: The Security tab may not be available for some services, depending on how they are configured. In this case, it is possible that the Winlogbeat service has been configured in a way that does not allow the Security tab to be displayed.
If none of the above solutions work, you can try using the command-line tool "sc.exe" to view or modify the security settings for the service. The syntax for using this tool is as follows:
sc.exe sdshow <servicename>
sc.exe sdset <servicename> <securitydescriptor>
Replace "<servicename>" with the name of the Winlogbeat service, and use "sdshow" to view the security descriptor and "sdset" to modify it.
I hope this helps you resolve the issue with accessing the Security tab for the Winlogbeat service.
