How to move taskbar to vertical position in windows 11?
2023-04-14T02:18:58+00:00
How do I move the task bar from horizontal position to vertical position? Company just installed windows 11 and I can't seem to figure out how to move it.
Windows for home | Windows 11 | Display and graphics
    2024-11-07T16:54:09+00:00
    Just had Win 11 forced on me and now have the menu bar at the bottom.
    As a developer this is unusable with 10-12 apps open, I am going to be severly hindered until this is fixed.
    Such a retrograde step, please stop removing funtionality.
    2024-11-15T03:36:38+00:00
    Some sources suggest....
    • Open Registry Editor (type regedit in the Start menu).
    • Navigate to: HKEY_CURRENT_USER\Software\Microsoft\Windows\CurrentVersion\Explorer\StuckRects3.
    • Find the DWORD value named Settings, and change its value to 01 for top, or 03 for bottom.
    • Restart Windows Explorer for changes to take effect
    2024-11-15T18:12:41+00:00
    We tried that, does not work... Thanks for the effort tho!
    2024-11-19T14:32:55+00:00
    please fix. no need to force users into a sub-optimal use of screen space.
    i never understood why anyone would want their taskbar at the bottom.
    as a software dev having all vertical space for my content is paramount.
    2024-11-21T20:20:23+00:00
    Dear Microsoft,
    Can you please be less snotty and bring back the vertical taskbar?
    Thank you in advance!
