How to move taskbar to vertical position in windows 11?
2023-04-14T02:18:58+00:00
How do I move the task bar from horizontal position to vertical position? Company just installed windows 11 and I can't seem to figure out how to move it.
Windows for home | Windows 11 | Display and graphics
    2023-04-14T02:24:54+00:00
    this is very very unfortunate. u CANT.
    Use Start11 to customize the start menu with almost the exact same settings as windows 10: https://www.stardock.com/products/start11/
    to revert to win10 taskbar, use StartAllBack to revert the taskbar to windows 10 with curved corners, do some consistency fixing within WIndows 11, and fix Windows Explorer: startallback.com
  2. Christine Luna 27,010 Reputation points Independent Advisor
    2023-04-14T02:56:44+00:00
    Hi Daniel,
    I'm Christine, a Windows user like you. I'll do my best to help you. I can see here that you would like into move your taskbar to vertical position. I feel you, there's a lot of users who are also looking for that option. However, please be informed that moving the taskbar is not yet available on Windows 11.
    You may raise your feedback or suggestions to Microsoft via Feedback Hub:
    Send feedback to Microsoft with the Feedback Hub app
    https://support.microsoft.com/en-us/windows/sen...
    Thank you,
    Christine L
    DISCLAIMER: This is a public peer to peer community forum. We are not a Microsoft Employees and we don't have access with MS Tools. Thank you.
    2023-07-25T14:53:52+00:00
    not happy with the windows release here.
    windows should have thought about retaining those before they release that update.
    i effectively work, same as the others having our task bars on the left side vertically. :(
    2023-08-08T08:26:34+00:00
    All those smart people always ask "how do you want to improve Windows?" and they just change things to show that they will do whatever they please.
    Why does Microsoft even ask?
    Just for appeasement, I'm sure.
    2023-11-01T02:27:11+00:00
    Are we to ask nicely to have a vertical task bar?
    May we please have features already available in Windows 10, 8, 7, Vista, XP.......
