My computer cursor won’t click on anything but it moves just fine , this is a windows ten I bought three years ago by the way. Anyone know why?
2023-04-30T18:03:39+00:00
My computer won’t click on anything at all but it moves just fine. The computer just started acting up this morning. Anyone know why?
Windows for home | Windows 10 | Accessibility
    2023-11-17T04:40:57+00:00
    I have the same issue.
    Mouse moves alright, but when clicking it takes lots of attempt before windows responds
    2023-08-29T18:44:11+00:00
    Hello!
    I did a lot of scanners and it says i dont got any malware or anything, its only doing it when i close one of my apps then i click twice and its working again is it then just the app or? cuz i dont got it everytime only when i close my app.
    2023-05-31T20:57:34+00:00
    My computer started doing the exact same thing after it wakes up from sleep. I can move the cursor around but it wouldn't let me click on things until about 1 min later.
    2023-04-30T18:37:40+00:00
    Hello! My name is Cristiano. I'm an Independent Advisor. I'm glad to help you.
    t's possible that there is an issue with your mouse or touchpad driver on your Windows 10 computer. You can try the following solutions to troubleshoot this issue:
    1. Try using a different mouse or touchpad and see if the issue persists.
    2. Update your computer's mouse or touchpad driver. You can do this by going to Device Manager, finding the mouse or touchpad driver, right-clicking on it, and selecting "Update driver".
    3. Reinstall the mouse or touchpad driver on your computer.
    If none of these solutions solve the problem, it's possible that there is a hardware issue with your mouse or touchpad that needs to be fixed.
    You may be interested in visiting https://answers.microsoft.com/en-us/windows/for...
    2023-04-30T18:15:37+00:00
    Hi Mariam,
    There can be several reasons for the issue you're experiencing. The most possible reason could be an outdated or corrupted I/O driver. You should try updating it to see if it solves the problem. If that doesn't work, there could be other causes, which I've listed below:
    • Restart your computer - Sometimes a simple restart can solve the problem.
    • Check your mouse or touchpad - Make sure that your mouse or touchpad is working properly. Try plugging in a different mouse or using an external touchpad if available.
    • Check the mouse settings - Make sure that the mouse settings are configured correctly in the Control Panel or Settings app.
    • Scan for malware - Malware or viruses can cause issues with your computer, including problems with your mouse. Run a malware scan to see if there are any infections.
    I hope this helps! Let me know if you have any other questions or concerns.
    best regards, Ashwin J.
