I have been having the same issue.
i9 14900k
32 GB DDR5 RAM
AUROS Z790 Master
RTX 4090 (MSI)
Windows 11
Lían-Li Unifans, Strimer RGB cable
MSI MEG CPU COOLER (with screen)
It will usually start randomly when a game is done loading or initializing, then on relaunch it will have a type of blue screen loop.
I have ran DSIM and SFC, replaced my RAM with two new sticks, reinstalled windows and partitioned all hard drives 3 times.
I have found a driver that appears to be showing unknown but anything I have tried to resolve it does not work. I cannot update it, if I uninstall it it is right there again, I have unplugged all external devices to see if it disappears.
Hey, I have the same exact problem as you and since a little bit of time have passed since you posted that I am wondering if you found any way to fix the problem. Thank you !
