Visual Basic Command Line Compiler is running at 85 % of my cpu and 100 % of the gpu while gaming
2023-04-23T08:12:33+00:00
Hi Community!
I want to disable the vbc.exe so that i can play my games smoothly without breaking or stuttering.
As soon as it starts, the game starts lagging. When I close it using the end task button in task manager, the game is alright but again after some time it pops up.
Pls help me.
I have been facing this for 6 months.
  1. DaveM121 936.1K Reputation points Independent Advisor
    2023-04-27T08:43:03+00:00
    Hi Armaan,
    Since nothing else has resolved this, the best option is to perform an in-place repair with the Windows 10 ISO to stabilize Windows.
    Please follow the steps, this is then just an update and your personal files, settings and installed software will not be affected.
    Click this link:
    https://www.microsoft.com/en-us/software-downlo...
    to download the Media Creation Tool (Click on Download Tool Now), with that you can download the latest Windows 10 ISO (Select Create Installation Media for Another PC), then choose ISO, not USB
    When the ISO file completes downloading
    Disconnect from the Internet
    Disconnect all external devices with the exception of a mouse or keyboard.
    Temporarily disable any 3rd party Anti-virus you may have installed
    Then, in Windows File Explorer, double click the ISO and then run Setup.exe and select the upgrade option.
  2. _AW_ 69,656 Reputation points Volunteer Moderator
    2023-04-27T08:49:16+00:00
    Please provide the Autoruns log as detailed in my previous post.
    2023-04-27T08:51:58+00:00
  4. _AW_ 69,656 Reputation points Volunteer Moderator
    2023-04-27T08:58:35+00:00
    I've requested access to the download. At present it says access denied.
    2023-04-27T08:59:29+00:00
    Will this reinstall Windows 10?
