Something went wrong. Try to reopen settings later windows update
2023-04-28T08:08:43+00:00
Hi all tried my all the settings shown on internet, such as window update services started yet the problem doesnt solves.
please anyone has its solution please help
    2023-04-28T08:47:43+00:00
    Hi! I'm Laurice, an Independent Advisor. I'm sorry you're having this problem. I will try my best to help you.
    Try running the Windows Update Troubleshooter to resolve the issue.
    Select Start > Settings > Update & Security > Troubleshoot > Additional troubleshooters. Next, under Get up and running, select Windows Update > Run the troubleshooter.
    When the troubleshooter is finished running, it's a good idea to restart your device.
    Next, check for new updates. Select Start > Settings > Update & Security > Windows Update > Check for updates and then install any available updates.
    You can refer to this article: https://support.microsoft.com/en-us/windows/win...
    Please let me know if you need any further assistance.
