There is a red target like a scope crosshair in the middle of my screen.
2023-05-01T01:23:39+00:00
Cannot turn it off. I can move it around but that's it. It overlays over anything on the screen.
    2024-04-20T23:27:00+00:00
    I encountered the same problem before. Your question prompted me to revisit the issue, and upon investigation, I discovered that it wasn't caused by any software on my PC. Rather, it was a feature within the screen itself called Game Plus mode. Toggling it off resolved the issue.
    2024-04-29T05:37:56+00:00
    hi i have tried this 2 times and it is still there and i have 0 clue what to try
    2024-04-29T05:39:56+00:00
    hi i have the same issue where do i find monitor setting?
    2024-04-29T05:49:23+00:00
    it is only 2/3 clicks to resolve. Try posting monitor details and OS for people to help. My monitor is a AGON Pro and red hairline (monitor) settings are all controlled by a wired 'puck' device and my monitor answer is within this.
    2024-05-01T05:25:58+00:00
    Use Ctrl+r and Run , msconfig .
    Disable everything that runs at startup that isn't essential. Then restart.
