can you send the step by step for removing the target symbol.
There is a red target like a scope crosshair in the middle of my screen.
Cannot turn it off. I can move it around but that's it. It overlays over anything on the screen.
2023-12-11T10:31:44+00:00 -
2023-12-12T16:40:00+00:00 What i did was Go into MSCONFIG and uncheck all the apps i had starting during startup. Red Cross hair disappeared. I then re-applied the check mark on apps that were driver/system stuff. rfestarted. No cross hair. Kept doing that to all the other apps. No Cross hair. I don't know what app was doing it but i got it to stop by doing this. Hope it works for you if that happens to you. Good Luck!
2024-01-07T22:44:05+00:00 My cat just did the exact same thing to my computer. *Facepalm*
2024-01-07T23:51:34+00:00 What I did to fix it was use msconfig and uncheck every program that is running on startup. Reboot the computer. It should now have a clean screen. Then use Ms config to put a check mark and the things you would like to run and restart the computer every time you make one or two check marks just to see. That's what I did in that fixed it. Hope this works for you.
2024-01-15T15:55:36+00:00 My cat must've enabled crosshairs on my keyboard when I left the home this morning. I came here to state that the simplest way in which I was able to remove the crosshairs was this:
Press and hold down FN on the keyboard and hit arrow right twice on the keyboard, then lift up, then press and hold FN again and hit arrow left. On my keyboard, the FN button and the Up, Down, Left, Right buttons are on the bottom righthand side of my keyboard. It removed the crosshairs immediately without having to reboot or close out any windows or tabs.
I'm running Windows 11 on a Pulse GL66 laptop with no external monitor. Hope this helps someone else in a bind!
