So cutting a long story short, it’s probably just a broken or multiple broken ram dimms?
Please help with my BSODS. I cannot get away from them!
Hi all.
Had this machine for a couple years.
The specs are listed below:
Operating System Windows 11 Pro 64-bit
CPU AMD Ryzen 7 3800X 49 °C Matisse 7nm Technology
RAM 32.0GB Dual-Channel DDR4 @ 3600MHz (18-22-22-42)
Motherboard ASUSTeK COMPUTER INC. ROG STRIX B550-F GAMING (AM4) 30 °C
Graphics S2719DGF (2560x1440@155Hz) DELL S2721HSX (1080x1920@60Hz) NVIDIA GeForce RTX 3070 (Gigabyte) 46 °C
Storage 931GB SanDisk SSD PLUS 1000GB (SATA (SSD)) 26 °C 931GB Western Digital WDC WD10EZRX-00L4HB0 (SATA ) 24 °C 238GB 256GB PCS 2.5" SSD (SATA (SSD)) 40 °C 238GB M Series NVMe SSD 256G
I keep getting random blue screens at random times and I cannot for the life of me figure out the problem. The BSOD I get are:
- IRQL_NOT_LESS_OR_EQUAL and the driver error in stack is "ntoskrnl.exe+44fa00"
- KMODE_EXCEPTION_NOT_HANDLED ntoskrnl.exe
- SYSTEM_THREAD_EXCEPTION_NOT_HANDLED bfs.sys
I have had a few BSODS since getting the machine and they're not always the same message though this is the most common.
I have tried the following:
- Both SFC and Dism commands on the local machine, and on a repair disk (No errors on both)
- Windows Memory Diagnostic and Memtest86 (No errors on both)
- Reinstalled Windows (Fixed for a short time)
- Reseated GPU
- Reseated RAM
- Updated Drivers
- Flashed BIOS with newest version (now OOD)
- Checked Temps
- Stress tested CPU and GPU.
I have all the latest drivers installed, and I have updated BIOS a few times hoping this would resolve the problem. I have ran SFC and DISM commands, and even re-installed Windows.
I just don't know what could be causing this, and funnily enough it doesn't seem to happen when I game (So far) it only ever happens if I am doing something random, or sometimes it will chain BSOD if it reboots and and I don't straight away start using my machine... like if it's left on the log in screen it would sometimes do it.
But it's perhaps once ever few days, or 3 times a day depending on it's mood.
Please help, I can provide any info necessary.
2023-06-01T07:09:10+00:00 -
DaveM121 935.1K Reputation points Independent Advisor2023-06-01T07:12:32+00:00 It is possible, but you indicated oy previously ran a full 4 pass scan with MemTest86 and your RAM passed that test, so most likely there is no problem with your RAM, it may be a corrupt driver causing the RAM corruption, but no specific driver is being listed in your dump files
2023-06-02T15:09:57+00:00 I've added 2 more :)
DaveM121 935.1K Reputation points Independent Advisor2023-06-02T15:16:25+00:00 That one also just contains generic RAM corruption, am beginning to doubt it is a driver, it may be a hardware issue it would be best now to get your hardware tested at a PC Repair shop.
2023-06-02T15:21:47+00:00 I've removed the 2 most recent installed ram sticks ( still over a year ago), but will see how this goes.
