Please help with my BSODS. I cannot get away from them!
2023-05-28T15:24:47+00:00
Hi all.
Had this machine for a couple years.
The specs are listed below:
Operating System Windows 11 Pro 64-bit
CPU AMD Ryzen 7 3800X 49 °C Matisse 7nm Technology
RAM 32.0GB Dual-Channel DDR4 @ 3600MHz (18-22-22-42)
Motherboard ASUSTeK COMPUTER INC. ROG STRIX B550-F GAMING (AM4) 30 °C
Graphics S2719DGF (2560x1440@155Hz) DELL S2721HSX (1080x1920@60Hz) NVIDIA GeForce RTX 3070 (Gigabyte) 46 °C
Storage 931GB SanDisk SSD PLUS 1000GB (SATA (SSD)) 26 °C 931GB Western Digital WDC WD10EZRX-00L4HB0 (SATA ) 24 °C 238GB 256GB PCS 2.5" SSD (SATA (SSD)) 40 °C 238GB M Series NVMe SSD 256G
I keep getting random blue screens at random times and I cannot for the life of me figure out the problem. The BSOD I get are:
  • IRQL_NOT_LESS_OR_EQUAL and the driver error in stack is "ntoskrnl.exe+44fa00"
  • KMODE_EXCEPTION_NOT_HANDLED ntoskrnl.exe
  • SYSTEM_THREAD_EXCEPTION_NOT_HANDLED bfs.sys
I have had a few BSODS since getting the machine and they're not always the same message though this is the most common.
I have tried the following:
  • Both SFC and Dism commands on the local machine, and on a repair disk (No errors on both)
  • Windows Memory Diagnostic and Memtest86 (No errors on both)
  • Reinstalled Windows (Fixed for a short time)
  • Reseated GPU
  • Reseated RAM
  • Updated Drivers
  • Flashed BIOS with newest version (now OOD)
  • Checked Temps
  • Stress tested CPU and GPU.
I have all the latest drivers installed, and I have updated BIOS a few times hoping this would resolve the problem. I have ran SFC and DISM commands, and even re-installed Windows.
I just don't know what could be causing this, and funnily enough it doesn't seem to happen when I game (So far) it only ever happens if I am doing something random, or sometimes it will chain BSOD if it reboots and and I don't straight away start using my machine... like if it's left on the log in screen it would sometimes do it.
But it's perhaps once ever few days, or 3 times a day depending on it's mood.
Please help, I can provide any info necessary.
    2023-05-28T16:24:19+00:00
    All done :)
  2. DaveM121 935.1K Reputation points Independent Advisor
    2023-05-28T16:29:27+00:00
    Your minidump files mostly indicate RAM corruption, but two indicate a virtual driver associated to the Quick Heal security software installed on your PC.
    Completely uninstall that software an wait to see if it is stable.
    2023-05-28T16:32:52+00:00
    Very strange!
    I don't actually have any Quick Heal Security Software installed that I know off... not by name at least.. Let me open up BCUninstaller and check.
    Update:
    I found CCleaner which I remembered I installed a couple weeks back, so wouldn't explain the 2 year issues.
    Same with Malwarebytes, that was a recent install.
    Does it state what Dimms could be causing the issue?
  4. DaveM121 935.1K Reputation points Independent Advisor
    2023-05-28T16:39:09+00:00
    Open File Explorer, then navigate to C:\WIndows\System32
    Search for bfs,sys
    When you find that file, right click it and choose Properties
    Please provide a screenshot of the Details tab of the resulting dialog box.
    2023-05-28T17:19:29+00:00
    here you go :)
