From 21H2 to 22H2 keep all data, apps, settings
2023-07-28T02:25:50+00:00
1
I have Windows 11 Pro for Workstations 21H2, bypass restrictions, I went upgrade to 22H2 keep all Apps, Settings and data, by inserting usb stick and pressing setup.exe, but I can Not proceed by keeping all, apps and data, i can keep only data... option keep also apps can Not selected,... any way proceed by keep apps, what about booting from usb rather than running setup.exe...?
2
Second Q posted also,
https://learn.microsoft.com/en-us/answers/questions/1338271/can-purchase-a-key-from-microsoft-and-remove-the-e
Development VMs evaluation version can I remove the evaluation mark, after purchasing and using a software OS key from Microsoft...?
Windows for home | Windows 11 | Licensing and activation
    2023-08-02T04:57:47+00:00
    Click on the More button (showing an ellipsis icon) and click Remove.
  2. Deleted
    2023-08-02T05:45:12+00:00
    Create a Restore Point and try the following:
    Open Regedit.exe and go to:
    HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Control\Nls\Language
    (From the File menu, export the key to a REG file.)
    In the right pane, double-click "Default" (REG_SZ) value and set it to 0409
    Double-click "InstallLanguage" (REG_SZ) value and set it to 0409
    Go to:
    HKEY_CURRENT_USER\Control Panel\Desktop\LanguageConfiguration
    Post a screenshot of that key.
    If the value data says en-US. then it's fine.
    Reboot and rerun Setup.
    2023-08-02T06:07:04+00:00
    Thanks for your support...!
    Where seem the en-US...? Seem "en-US" or its language code ...?
    I will do soon, because I have to go to my office for work as a software developer now, i will be do on my return,...
    2023-08-02T06:07:08+00:00
    This is a trial and error step:
    Boot to the Windows Media Creation Tool (MCT) > command prompt >
    (Type:)
    bcdedit | find "osdevice"
    (identify the partition drive letter while in Windows RE)
    (Type:)
    dism.exe /image:w:\ /set-uilang:en-us
    (change the drive letter w to the identified partition drive letter)
    (reboot)
    Open administrative command prompt and copy and paste:
    dism /online /get-intl
    If the default language is en-us then attempt an upgrade.
