Can't uninstall Power Toys
Reported
2023-06-02T22:03:29+00:00
I had trouble updating Power Toys, so I downloaded the installer. The installer won't work because Power Toys is already installed. However, it doesn't show up in my app list, so an uninstaller can't find it. I tried to restore the system from a disc image, but that didn't even get started. How can I get out of this situation?
    2023-06-04T11:35:38+00:00
    Are you able to run Powershell from %APPDATA%\Microsoft\Windows\Start Menu folder?
    2023-06-04T11:42:31+00:00
    Yes; I have a link to it on my desktop.
    2023-06-04T11:48:18+00:00
    Thanks, Roger. Return to this path, copy the shortcut then open Programs folder and replace the other Powershell icon.
    2023-06-04T12:19:05+00:00
    Which path? I see dozens of "Programs" folders.
    2023-06-04T16:01:35+00:00
    Roger, according to the error, the path is: C:\Users\Admin\AppData\Roaming\Microsoft\Windows\Start Menu\Programs\Windows PowerShell
    One of the shortcuts listed here is not working and must be replaced. Test everyone and let me know which one is not working, please.
