How to disable Caps Lock notification?
2023-06-20T13:49:40+00:00
Hi everyone there is this annoying caps lock notification thats pops up on the top middle of my screen when I'm in a game it switches out the tabs and it freezes my computer hence I would like to get rid of it, I already tried the ease of access thing and turned of the unnecessary notifications but it still pops up please help my computer is a lenovo think pad T460
Windows for home | Windows 10 | Accessibility
2024-04-24T11:09:38+00:00
on an HP computer click on Start and type HP System Event Utility: right click on it and remove this application, this will stop caps and num notification.
Cesare
2023-10-24T21:16:36+00:00
I had the same thing happening on my Dell laptop. I had to go to Computer Management -> Services -> Dell Peripheral Manager and stop the service. That immediately stopped the annoying notifications. I set that service to start manually instead of automatic. I hope this helps someone.
96 additional answers
    2024-12-29T16:39:40+00:00
    yes, this is actually a dell notification. very stupid for them to do that, especially for games.. uninstalled dell software completely.
    2025-01-08T05:28:49+00:00
    Instead of disabling the service, you can open "Dell Peripheral Manager" from the Windows Start Menu, then go to the Configuration/Settings of the app, and uncheck the "Enable lock key notifications" under "On Screen Notifications"
    2025-01-28T16:51:23+00:00
    Did not work on my Dell laptop, but thank you!
