How to disable Caps Lock notification?
2023-06-20T13:49:40+00:00
Hi everyone there is this annoying caps lock notification thats pops up on the top middle of my screen when I'm in a game it switches out the tabs and it freezes my computer hence I would like to get rid of it, I already tried the ease of access thing and turned of the unnecessary notifications but it still pops up please help my computer is a lenovo think pad T460
Windows for home | Windows 10 | Accessibility
2024-04-24T11:09:38+00:00
on an HP computer click on Start and type HP System Event Utility: right click on it and remove this application, this will stop caps and num notification.
Cesare
2023-10-24T21:16:36+00:00
I had the same thing happening on my Dell laptop. I had to go to Computer Management -> Services -> Dell Peripheral Manager and stop the service. That immediately stopped the annoying notifications. I set that service to start manually instead of automatic. I hope this helps someone.
96 additional answers
  1. Deleted
  2. Ramesh 181.4K Reputation points Volunteer Moderator
    2024-04-27T05:22:08+00:00
    If you have an HP system, open Settings → Apps & Features. Uninstall "HP System Event Utility."
    Turn off Caps Lock OSD Notification on HP Systems » Winhelponline: https://www.winhelponline.com/blog/caps-lock-on-screen-notifications-hp/
    2024-04-27T08:08:48+00:00
    worked for me, thanks.
