How to connect My Airpods to my computer
2023-07-06T10:24:15+00:00
I'm trying to connect my Airpods to my computer and they wont even come up when searching for bluetooth device
2023-07-06T10:58:30+00:00
Hi Padraig,
I'm Amr, an independent advisor.
Follow these steps to connect your AirPods to a Windows laptop.
  1. Put the AirPods into their charging case
Close the case and wait a few seconds. Ideally, the AirPods should have at least 20% battery before you pair them to your laptop.
  1. Open the AirPods case
Open the case and leave the AirPods inside while you follow the rest of these steps.
  1. Press and hold the Setup button
The Setup button is the small, circular button on the backside of the case. Hold it down until you see the LED lights flashing on the inside (older AirPods) or front (AirPods Pro).
The Setup button puts the AirPods into pairing mode, an essential step for pairing any Bluetooth device.
  1. Open the Start Menu
Click the Windows logo on your laptop to open the Start Menu on your laptop. With Windows 10, you’ll find it in the bottom left corner. Windows 11 users will see it in the bottom taskbar.
  1. Go to Settings
Find the gear-shaped icon and click it to open Settings.
  1. Open Bluetooth & devices
Windows 11 users should click Bluetooth & devices on the left-hand column. If you’re on Windows 10, click Devices on the Settings icon menu, then click Bluetooth & devices on the left column.
  1. Add a new Bluetooth device
On Windows 10, click Add Bluetooth to other devices next to the grey plus icon. Windows 11 users must click the blue Add Device button within the Devices row.
  1. Choose Bluetooth
A pop-up screen will give you the options of Bluetooth, Wireless display or dock, and Everything else.
Choose Bluetooth.
  1. Select your AirPods
After a few seconds, a list of available Bluetooth devices will load on the Add a device window. Click the icon for your AirPods.
  1. Click Done
A window will pop up, declaring, “Your device is ready to go.” Click Done.
I hope this is helpful. If you require any additional assistance, don't hesitate to respond to this.
This is a user-to-user support forum. We're users just like you helping other users to find solutions to their problems.
Best Regard
Amr
1000+ people found this answer helpful.
72 additional answers
    2024-04-03T16:29:06+00:00
    Awesome! it worked perfectly. Thanks.
    2024-04-10T21:03:47+00:00
    It says its connected but I cant hear any audio
    2024-04-22T20:19:29+00:00
    I dont have airpods from apple I have them from jvc
    2024-04-30T06:40:03+00:00
    how to connet in window 7
