Dev Home (Peview)
2023-09-26T23:06:30+00:00
I see Microsoft is at it again... forcing new UNINSTALLABLE apps in the latest update (Sept 26/2023) to us... What the heck is Dev Home (Preview) and what does it do and how can you get rid of it???
2023-09-27T11:46:24+00:00
If you had Dev Home (Preview) installed during the September 26/2023 update and don't want it...
I did a lot of seaching, I found a way to get rid of it...
A - To uninstall Dev Home Preview, you can follow the steps below:
Open the Settings app.
Click on Apps.
Scroll down and locate Dev Home Preview.
Click on it and select Uninstall.
B - If you are unable to uninstall Dev Home Preview using the above method, you can try using PowerShell to remove it. Here are the steps:
Open PowerShell (Terminal) as an administrator.
Type
Get-AppxPackage *devhome* | Remove-AppxPackage
and press Enter.
This should remove Dev Home Preview from your device.
I hope this helps! Let me know if you have any other questions.
B worked perfectly for me... doing that removed it from the Start Menu... Microsoft Store and Settings - Apps
How to uninstall Dev Home in Windows 11 - Your Windows Guide
47 additional answers
    2023-10-17T11:36:13+00:00
    MS should offer beta test software after telling us what it is for. Until accepted by the user the new software should not be downloaded not should updates. Forcing me to spend a couple of hours to get rid of a program that wouldn't have served any purpose for me is bad marketing
    There are a lot of methods to remove Home Dev (Preview), but none of them worked until I found the solution above which took me a few hours to find
    2023-10-26T19:24:29+00:00
    Thank you so much Jack for your solution to get rid of Dev Home Preview!
    2023-10-29T12:55:45+00:00
    it does not work for me.. any other solution ?
    2023-10-29T13:40:17+00:00
    it works... what is the exact command you are entering in Terminal (Admin)?
