Dev Home (Peview)
2023-09-26T23:06:30+00:00
I see Microsoft is at it again... forcing new UNINSTALLABLE apps in the latest update (Sept 26/2023) to us... What the heck is Dev Home (Preview) and what does it do and how can you get rid of it???
2023-09-27T11:46:24+00:00
If you had Dev Home (Preview) installed during the September 26/2023 update and don't want it...
I did a lot of seaching, I found a way to get rid of it...
A - To uninstall Dev Home Preview, you can follow the steps below:
Open the Settings app.
Click on Apps.
Scroll down and locate Dev Home Preview.
Click on it and select Uninstall.
B - If you are unable to uninstall Dev Home Preview using the above method, you can try using PowerShell to remove it. Here are the steps:
Open PowerShell (Terminal) as an administrator.
Type
Get-AppxPackage *devhome* | Remove-AppxPackage
and press Enter.
This should remove Dev Home Preview from your device.
I hope this helps! Let me know if you have any other questions.
B worked perfectly for me... doing that removed it from the Start Menu... Microsoft Store and Settings - Apps
How to uninstall Dev Home in Windows 11 - Your Windows Guide
47 additional answers
  1. Deleted
    2023-10-13T22:22:51+00:00
    How many users are app developers. Why would MS install this on every machine.
    I'm a developer, but guess why I am here?
    Because its's a pointless app and the uninstall button was grayed out.. 😅
    Win 11 is so bloated, I had to change group policies to prevent Teams to come back and to disable widgets..
    2023-10-16T08:35:53+00:00
    If I had to guess given their reply above, this is a bug in the preview version - it is a preview after all, part of a feature preview update that's quite intentionally marked as not-final. It really sounds like they only expect it to be installed based on the personalization options, but something goes awry and it flags every machine as "install this Dev Home thing".
    Basically, don't go for preview updates.
    2023-10-17T00:45:28+00:00
    MS should offer beta test software after telling us what it is for. Until accepted by the user the new software should not be downloaded not should updates. Forcing me to spend a couple of hours to get rid of a program that wouldn't have served any purpose for me is bad marketing
