Dev Home (Peview)
2023-09-26T23:06:30+00:00
I see Microsoft is at it again... forcing new UNINSTALLABLE apps in the latest update (Sept 26/2023) to us... What the heck is Dev Home (Preview) and what does it do and how can you get rid of it???
2023-09-27T11:46:24+00:00
If you had Dev Home (Preview) installed during the September 26/2023 update and don't want it...
I did a lot of seaching, I found a way to get rid of it...
A - To uninstall Dev Home Preview, you can follow the steps below:
Open the Settings app.
Click on Apps.
Scroll down and locate Dev Home Preview.
Click on it and select Uninstall.
B - If you are unable to uninstall Dev Home Preview using the above method, you can try using PowerShell to remove it. Here are the steps:
Open PowerShell (Terminal) as an administrator.
Type
Get-AppxPackage *devhome* | Remove-AppxPackage
and press Enter.
This should remove Dev Home Preview from your device.
I hope this helps! Let me know if you have any other questions.
B worked perfectly for me... doing that removed it from the Start Menu... Microsoft Store and Settings - Apps
How to uninstall Dev Home in Windows 11 - Your Windows Guide
47 additional answers
    2023-10-08T08:44:14+00:00
    I checked this and found that that I did NOT have 'Development' turned on but this package had downloaded and installed anyway.
    However the 'B' solution given above worked fine.
    2023-10-08T12:19:23+00:00
    Microsoft has to stop force installing apps people don't want or need without an easy way to uninstall them.
    2023-10-08T20:19:44+00:00
    Better would be to have MS invite users to install new stuff, not just stick in a routine update and leave it to users to figure out what the #@&%! it is doing and have to conduct an hour or two research to get rid of it.
    2023-10-12T01:16:34+00:00
    option A not available; option B worked well.
    This seems to be an app solution in search of a problem. What does it really do?
