Dev Home (Peview)
2023-09-26T23:06:30+00:00
I see Microsoft is at it again... forcing new UNINSTALLABLE apps in the latest update (Sept 26/2023) to us... What the heck is Dev Home (Preview) and what does it do and how can you get rid of it???
2023-09-27T11:46:24+00:00
If you had Dev Home (Preview) installed during the September 26/2023 update and don't want it...
I did a lot of seaching, I found a way to get rid of it...
A - To uninstall Dev Home Preview, you can follow the steps below:
Open the Settings app.
Click on Apps.
Scroll down and locate Dev Home Preview.
Click on it and select Uninstall.
B - If you are unable to uninstall Dev Home Preview using the above method, you can try using PowerShell to remove it. Here are the steps:
Open PowerShell (Terminal) as an administrator.
Type
Get-AppxPackage *devhome* | Remove-AppxPackage
and press Enter.
This should remove Dev Home Preview from your device.
I hope this helps! Let me know if you have any other questions.
B worked perfectly for me... doing that removed it from the Start Menu... Microsoft Store and Settings - Apps
How to uninstall Dev Home in Windows 11 - Your Windows Guide
47 additional answers
    2023-09-29T01:27:56+00:00
    Ref choice A. Uninstall is greyed out. Why would the uninstall be greyed out by MS. How many users are app developers. Why would MS install this on every machine. In the past a patch would inform PC owner what is being installed and could choose what to install.
    2023-09-29T12:55:13+00:00
    Insanity? On drugs? :) :)
    2023-09-30T00:06:16+00:00
    Alle twee geprobeerd, maar DEV HOME kan niet verwijderd worden. Blijf staan, ook na computer uit zetten en weer aan zetten.
    2023-09-30T00:29:28+00:00
    Tried both, but DEV HOME cannot be removed. Stay standing, even after turning off the computer and turning it on again.
    Right click Start menu and click Terminal (Admin)... formerly called Powershell (Admin).
    Then copy and paste
    Press enter
    It does work
