Dev Home (Peview)
2023-09-26T23:06:30+00:00
I see Microsoft is at it again... forcing new UNINSTALLABLE apps in the latest update (Sept 26/2023) to us... What the heck is Dev Home (Preview) and what does it do and how can you get rid of it???
2023-09-27T11:46:24+00:00
If you had Dev Home (Preview) installed during the September 26/2023 update and don't want it...
I did a lot of seaching, I found a way to get rid of it...
A - To uninstall Dev Home Preview, you can follow the steps below:
Open the Settings app.
Click on Apps.
Scroll down and locate Dev Home Preview.
Click on it and select Uninstall.
B - If you are unable to uninstall Dev Home Preview using the above method, you can try using PowerShell to remove it. Here are the steps:
Open PowerShell (Terminal) as an administrator.
Type
Get-AppxPackage *devhome* | Remove-AppxPackage
and press Enter.
This should remove Dev Home Preview from your device.
I hope this helps! Let me know if you have any other questions.
B worked perfectly for me... doing that removed it from the Start Menu... Microsoft Store and Settings - Apps
How to uninstall Dev Home in Windows 11 - Your Windows Guide
47 additional answers
    2024-02-14T19:07:08+00:00
    Thanks to Jack Smook for the fix. This type of system hijacking by Microsoft is pitiful.
    2024-02-20T12:52:23+00:00
    I have the same question. What in the heck is Dev Home (Preview)?
    2024-03-13T00:00:12+00:00
    Het helpt niet, komt iedere keer terug bij updates.
    2024-03-13T23:25:22+00:00
    NOPE!!! Did not check the dev tool box nor did I check the app for malicious Russian script. All free!!!!
