Minecraft Loading Issue (Stuck on Loading Process)
2023-09-27T16:14:16+00:00
Hey, There!
I'm a user of Windows! From a couple of days, I've been experiencing this issue.
Whenever I open the Minecraft app, it gets stuck at 35% loading process.
Before this issue occur, I had copied my old minecraft world folder from another drive to C Drive.
Since then, this issue is happening!
Kindly help...
Minecraft Version: Minecraft Bedrock for Pc (trial)
Windows Version: Windows 10 Home (Latest Version)
Graphics: Updated to the latest version
    2024-11-07T19:08:38+00:00
    I had the same problem but found a fix I plugged in a pair of headphones/earbuds and I played around with the computers sound settings and I made sure that Minecraft was using the headphones as an output and then it took a bit but it worked I hoped this helped
    2024-11-14T03:31:19+00:00
    You need to install the launcher from the official minecraft website that should do the trick
    2024-11-14T03:34:16+00:00
    Install minecraft from the website dont get it from the microsoft store its buggy ash
  4. Deleted
    2025-01-03T03:38:49+00:00
    Open your Speakers/Headphones Properties and click on whichever speaker you're currently using. Once there, please perform the following:
    • Go to the 'Advanced' tab
    • Under 'Default Format', you'll see a dropdown for multiple different settings
    • Switch this to '16 bit, 192000 Hz (Studio Quality)' if this is set to anything else
    • Click 'Apply' and close these settings
    • Restart your computer
    • Open the Minecraft launcher and open the game
    It should work properly now.
    MRA
