when i open minecraft bedrock edition on my pc then it gets stuck on 34 or 38percent and when i reopen and restart it then it also reacts not good and dont load
Minecraft Loading Issue (Stuck on Loading Process)
Hey, There!
I'm a user of Windows! From a couple of days, I've been experiencing this issue.
Whenever I open the Minecraft app, it gets stuck at 35% loading process.
Before this issue occur, I had copied my old minecraft world folder from another drive to C Drive.
Since then, this issue is happening!
Kindly help...
Minecraft Version: Minecraft Bedrock for Pc (trial)
Windows Version: Windows 10 Home (Latest Version)
Graphics: Updated to the latest version
Deleted
2023-12-10T14:21:21+00:00 -
2023-12-19T05:31:07+00:00 Unfortunately this didn't work for me. The only compatible driver with the realtek audio device was the realtek driver from 2020. Is this a bug with Minecraft or the driver? Hopefully it's minecraft and it will be fixed. I doubt my pc will get a new driver update. The workaround of loading a youtube video and letting it play while i launch minecraft bedrock or java worked for me. Once you are in the minecraft game the youtube video can be closed.
2024-02-19T15:36:30+00:00 Hey, There!
Kindly help...
Credit goes to @Lukasz Redzinski from another thread, but the solution is so simple. It's a Realtek audio driver issue. I uninstalled it from Control Panel, restarted and the computer still had audio AND Minecraft loaded right up!
2024-02-20T09:20:31+00:00 There's one more fix for it.
> Open Device Manager
> Then expand, "Sound, video and game controllers"
> Select the "Realtek(R) audio" and right-click then select "Update Driver"
> In the dialog box, select the second option that says, "Browse my computer for drivers"
> Then select, "Let me pick from a list of available drivers on my computer"
> There will be two options to choose. Select the, "High Definition Audio Device"
> Click Next, after that click YES and it will ask you to restart your device to apply the new settings.
This will also fix the issue!
