Minecraft Loading Issue (Stuck on Loading Process)
2023-09-27T16:14:16+00:00
Hey, There!
I'm a user of Windows! From a couple of days, I've been experiencing this issue.
Whenever I open the Minecraft app, it gets stuck at 35% loading process.
Before this issue occur, I had copied my old minecraft world folder from another drive to C Drive.
Since then, this issue is happening!
Kindly help...
Minecraft Version: Minecraft Bedrock for Pc (trial)
Windows Version: Windows 10 Home (Latest Version)
Graphics: Updated to the latest version
    2025-02-28T08:11:18+00:00
    im also having the same issue, it just gets stuck in 41%, crashes the audio, and then after relaunch, stuck on 35.
    2025-03-06T03:46:51+00:00
    On mobile or Android And ios and Windows 7/10/11 : Trun off your wifi and open the app again. And then the loading screen is done. Trun on your wifi
    And done.
    this is may to a problem to Mojang.
    We Will fix it soon. Contact to Mojang to fix this Error.
    2025-03-28T22:11:29+00:00
    Hey bro.. is the problem solved? If not... Here's what I did...
    So, somehow I found this way of bypassing it.
    Only works on laptop.. idk for you desktop people
    Go to any browser and play any video on yt.. THIS IS IMPORTANT! it keeps your audio in Minecraft...
    If your laptop is plugged in, plug it off..
    Then, AND ONLY THEN
    Open Minecraft
    Do the task manager thing if it got stuck again..
    If succeeded, you can turn off that yt video and plug your laptop back in...
    it works for me... So I guess you could give it a go...
    For the desktop folks, sorry idk
    And if this doesn't work.. well at least you tried...
