Random Restarts When Idle
2023-08-19T11:34:19+00:00
My computer keeps randomly restarting when left idle for a bit. I have attached my .dmp files.
Assistance would be greatly appreciated!
https://drive.google.com/drive/folders/1ZGwHST52tMmk0JeDmp37KhZA1E0kaT57?usp=drive_link
  1. DaveM121 935.1K Reputation points Independent Advisor
    2023-08-23T12:33:46+00:00
    If the system crashes have survived a clean install of Windows from a bootable USB and you have then installed all drivers, then that would indicate some faulty hardware or a hardware conflict, BSOD's should not survive re-installing Windows.
    2023-08-23T12:40:24+00:00
    "...then installed all drivers"
    Okay how can I ensure I've done all this correctly? When I look at that dmp file using WhoCrashed, it talks about a potential driver error.
  3. DaveM121 935.1K Reputation points Independent Advisor
    2023-08-23T12:43:12+00:00
    After installing Windows, the best option is to install all recommended drivers from the support page for your PC.
    What driver is the WhoCrashed utility indicating on your PC?
    2023-08-23T12:50:11+00:00
    This is what it is reporting with the most recent crash:
  5. DaveM121 935.1K Reputation points Independent Advisor
    2023-08-23T12:56:44+00:00
    That is just the standard output from WhoCrashed when it cannot work out what the underlying problem is.
