RESOLVED: Explorer crashing on right click
2023-09-04T10:51:57+00:00
Explorer.exe keeps crashing when I right click in a window or on the desktop. This seemed to start happening randomly and not after a Windows update or anything in particular.
I have tried the following:
-Disabled antivirus
-Disabled context menu's using ShellExView
-Booting into safemode
-Updating Windows
-Reinstalling the graphics driver
-sfcscan
-DISM repair
-Clear file explorer history
-Disable credential Guard in regedit
The same problem continues to happen, even in safemode.
Eventviewer displays the following when explorer crashes due to a right click:
Faulting application name: explorer.exe, version: 10.0.22621.2215, time stamp: 0xb9c28810
Faulting module name: Windows.UI.FileExplorer.dll, version: 10.0.22621.2215, time stamp: 0xaaa66d5d
Exception code: 0xc0000005
Fault offset: 0x000000000004e730
Faulting process ID: 0x0x1918
Faulting application start time: 0x0x1D9DF1AA34B61BA
Faulting application path: C:\WINDOWS\explorer.exe
Faulting module path: C:\WINDOWS\SYSTEM32\Windows.UI.FileExplorer.dll
Report ID: 9e3a2452-7da8-457c-a92d-d1db4f58f23a
Faulting package full name:
Faulting package-relative application ID:
I'm stumped and don't know what else I can do. Any suggestions?
Windows 11 Home 22H2 (OS Build 22621.2215)
2023-09-04T14:45:47+00:00
Hello again,
I just fixed the issue without the need to run a repair.
I used the following command to disable the new context menu.
reg.exe add "HKCU\Software\Classes\CLSID{86ca1aa0-34aa-4e8b-a509-50c905bae2a2}\InprocServer32" /f /ve
The problem is now resolved.
63 additional answers
    2024-03-05T22:42:32+00:00
    Someone already posted that they tried a fresh install of W11 and it still crashed
    2024-03-05T23:08:42+00:00
    I have too but I installed it and then installed everything I use which is quite a lot.
    So if one of the many hundreds of programs (Games) new and retro is the problem I wouldn’t know which one it is.
    I intend to have a triple windows system with a fresh install of windows 10 and 11 together with my present one .
    So I can test the 2 fresh installs after adding bits of my stuff.
    Then when Ive had enough for the day of that I can load my present version of windows and mess about and play some games.
    Just bought a 2TB Crucial P3 Plus NVME M.2 ssd drive (comes with a free Cooler Master MM731 wireless mouse) from Ebuyer.
    I will transfer my stuff from one of my WD Black SN850X 2TB NVME M.2 SSD onto the new drive and partition the Faster WD one for the 2 fresh widows versions.
    2024-03-05T23:15:17+00:00
    I’ve always upgraded my pc to the low/low medium standard but as I’m getting on a bit decided to have a top of the range pc for once.
    Didn’t expect to have to fight with it but in a way it’s all part of the fun.
    Sorry if I’ve bored the pants off you but if I ever find an answer or clue to our problem I’ll let you know.
    Windows 12 might be the answer, who knows?
    Regards Steven
    2024-03-06T09:43:59+00:00
    One has to ask in this case where the Windows copy came from. Was it freshly downloaded from the MS site or from a DVD etc. And then, were all the settings etc backed up and restored? It makes no sense that a fresh install from MS would come stock with a problem with right clicking. It's nothing I've heard of before. If it really is a fresh install with nothing restored at all, I'd look at a driver being the culprit. Roll back to an older graphics driver for example, or just for testing purposes, no Nvidia/AMD drivers at all and just the basic VGA driver to see if the problem persists.
