RESOLVED: Explorer crashing on right click
2023-09-04T10:51:57+00:00
Explorer.exe keeps crashing when I right click in a window or on the desktop. This seemed to start happening randomly and not after a Windows update or anything in particular.
I have tried the following:
-Disabled antivirus
-Disabled context menu's using ShellExView
-Booting into safemode
-Updating Windows
-Reinstalling the graphics driver
-sfcscan
-DISM repair
-Clear file explorer history
-Disable credential Guard in regedit
The same problem continues to happen, even in safemode.
Eventviewer displays the following when explorer crashes due to a right click:
Faulting application name: explorer.exe, version: 10.0.22621.2215, time stamp: 0xb9c28810
Faulting module name: Windows.UI.FileExplorer.dll, version: 10.0.22621.2215, time stamp: 0xaaa66d5d
Exception code: 0xc0000005
Fault offset: 0x000000000004e730
Faulting process ID: 0x0x1918
Faulting application start time: 0x0x1D9DF1AA34B61BA
Faulting application path: C:\WINDOWS\explorer.exe
Faulting module path: C:\WINDOWS\SYSTEM32\Windows.UI.FileExplorer.dll
Report ID: 9e3a2452-7da8-457c-a92d-d1db4f58f23a
Faulting package full name:
Faulting package-relative application ID:
I'm stumped and don't know what else I can do. Any suggestions?
Windows 11 Home 22H2 (OS Build 22621.2215)
2023-09-04T14:45:47+00:00
Hello again,
I just fixed the issue without the need to run a repair.
I used the following command to disable the new context menu.
reg.exe add "HKCU\Software\Classes\CLSID{86ca1aa0-34aa-4e8b-a509-50c905bae2a2}\InprocServer32" /f /ve
The problem is now resolved.
63 additional answers
    2023-12-21T17:19:25+00:00
    No problem man. Glad it fixed your problem.
    2024-01-30T12:06:22+00:00
    this simply does not do anything
    2024-01-30T12:43:46+00:00
    Yes it does. It disables the new context menu which has caused some people problems. If it didn't do anything then it wouldn't have fixed my problem and the other guy who posted here to say thanks for solving his issue.
    So it simple does do something. It fixes the issue with the new context menu.
    2024-01-30T12:57:57+00:00
    It may have worked for you and others, but it certainly does not do anything for me either. It's a real crappy problem as I am very used to selecting multiple files and use the SendTo menu item 😒
