RESOLVED: Explorer crashing on right click
2023-09-04T10:51:57+00:00
Explorer.exe keeps crashing when I right click in a window or on the desktop. This seemed to start happening randomly and not after a Windows update or anything in particular.
I have tried the following:
-Disabled antivirus
-Disabled context menu's using ShellExView
-Booting into safemode
-Updating Windows
-Reinstalling the graphics driver
-sfcscan
-DISM repair
-Clear file explorer history
-Disable credential Guard in regedit
The same problem continues to happen, even in safemode.
Eventviewer displays the following when explorer crashes due to a right click:
Faulting application name: explorer.exe, version: 10.0.22621.2215, time stamp: 0xb9c28810
Faulting module name: Windows.UI.FileExplorer.dll, version: 10.0.22621.2215, time stamp: 0xaaa66d5d
Exception code: 0xc0000005
Fault offset: 0x000000000004e730
Faulting process ID: 0x0x1918
Faulting application start time: 0x0x1D9DF1AA34B61BA
Faulting application path: C:\WINDOWS\explorer.exe
Faulting module path: C:\WINDOWS\SYSTEM32\Windows.UI.FileExplorer.dll
Report ID: 9e3a2452-7da8-457c-a92d-d1db4f58f23a
Faulting package full name:
Faulting package-relative application ID:
I'm stumped and don't know what else I can do. Any suggestions?
Windows 11 Home 22H2 (OS Build 22621.2215)
2023-09-04T14:45:47+00:00
Hello again,
I just fixed the issue without the need to run a repair.
I used the following command to disable the new context menu.
reg.exe add "HKCU\Software\Classes\CLSID{86ca1aa0-34aa-4e8b-a509-50c905bae2a2}\InprocServer32" /f /ve
The problem is now resolved.
63 additional answers
  1. Deleted
  2. Deleted
    2024-08-24T14:53:27+00:00
    THANK YOU SO MUCH.
    I had been having problems with my laptop and went for a full install again keeping my settings and documents.
    Then the right click crashes started.
    SFC /Scannow said all was well.
    Event Viewer had
    Faulting application name: explorer.exe, version: 10.0.22621.2792, time stamp: 0xfbda1990
    Faulting module name: ntdll.dll, version: 10.0.22621.2506, time stamp: 0xbced4b82
    Exception code: 0xc0000374
    Fault offset: 0x000000000010c7a9
    Faulting process id: 0x0x3B8C
    Faulting application start time: 0x0x1DAF634297CA27A
    Faulting module path: C:\WINDOWS\SYSTEM32\ntdll.dll
    Report Id: e184c88d-8419-4242-8bf9-3f4702f7cf03
    Your reg.exe add fixed the issue.
    Thank again.
    2024-08-30T15:47:11+00:00
    Many thanks! Solved the problem immediately. Makes my life a lot easier.
