PC restarts randomly with no BSOD
2023-09-05T03:04:47+00:00
My PC restarts randomly with no BSOD or anything. Just a black screen and straight restart. This has been happening consistently for 2 days, but has happened like 1-2 times before that as well. It's out lf control now, however.
Today, my PC was consistently restarting around 2-3 minutes after booting up and arriving to desktop. I reinstalled windows ("dirty" install) and the frequency dropped but it's still happening randomly.
It mostly happens with games, like halfway into a MW2 Multiplayer or CSGO match or in the Starfield menu (but Starfield has been having such issues anyway). However, this is not exclusive and the PC does restart at any point when not in game, although it does take significantly longer to do so when I'm just browsing or doing anything other than playing.
I thought reinstalling Windows 10 would fix it but well, it didn't. There are a few different errors in the event log that are causing the "kernel" event that basically means the PC was restarted but not in the proper way, but we already know that.
Need help, people. I'll provide anything I can to help.
MSI 6600XT
Ryzen 5 5600
Asrock B450M
Corsair Vengeance 2x8GB DDR4 3000 mhz
Corsair VS450
    2024-06-03T15:58:57+00:00
    Mine is random. It's happened while I was playing games, watching videos (streaming/youtube), and while just navigating folders or just general usage.
    I've ruled out a lot of things including a lot of hardware. I'm going to be checking one last thing with making sure the BIOS is up to date because I've read that can cause issues, but beyond that, I'm probably installing a new motherboard. By that point it will be a new computer.
    Good luck.
    2024-06-14T19:26:33+00:00
    HI, this sounds like unstable CPU overclock ( low voltage ). try to run bios with default setting only enabling xmp.
    2024-06-27T00:46:25+00:00
    Hey OP. Not sure how to help you specifically, but I encountered a similar situation. I think that these 5000 series CPUs aren't receiving enough voltage when it enters a lower power state. I would recommend adjusting your curve optimizer if you have one or disabling ACPI sleep states. Ryzen 5000 CPUs are also sometimes unstable with RAM clocked at 3600mhz, so you could try bringing it down a bit.
    Idk if any of this will work for you, but it worked on my gf's machine who was having the same problem.
    Her specs are
    EVGA X570 FTW
    AMD Ryzen 5800x
    RTX 3070 Ti FE
    Corsair Vengeance LPX 32GB 4x8 DDR4
    Corsair 850 watt gold (don't remember what type)
    Boot drive - samsung 970 EVO NVME 2 TB
    2024-06-28T20:22:29+00:00
    I have the same Problem, and it just does even while being idle on desktop running nothing than OS.
    I've put the recent Mini dumb files in the link. Appreciate any help and thank you in advance.
    Minidumb
    Specs
    AMD Ryzen 5 5600X 6-Core Processor, 3701 Mhz, 6 Core(s), 12 Logical Processor(s)
    MSI B450 GAMING PLUS MAX (MS-7B86)
    Kingston 48,0 GB Ram (2x16 - 2x8)
    Radeon RX 5500 XT
    PSU 650W
    2024-07-01T12:56:20+00:00
    So I actually found out what my problem was. It did end up being a hardware issue but not the hardware I was ever going to suspect: the actual case of the PC itself.
    After deciding to upgrade some hardware since it was getting up in years, the same issue was happening despite it being essentially a new computer. Black screens and rebooting.
    I decided to see if the case was the issue. I unplugged all the connectors from the I/O to the motherboard: power button, reset switch, LED, USB, HD audio, etc. I disconnected the fans to play it safe. I took a flathead screwdriver and booted up the PC by briefly connecting the pins on the power switch on the motherboard and testing that for about a week. The system was completely stable. Operated just fine, played games normally. I could put it to sleep and wake it up with no issues.
    So I ended up getting a new PC case and it's been running smoothly ever since.
    Can't say this is the case for everyone else but it was for me.
