Did That And Looks The Same So Now What ?
System Restore
While Trying To Create A Restore Point In System Restore I Get The Following Error Message .
"The Restore Point Could Not Be Created For The Following Reason : Insufficient Storage Available To Create Either A Shadow Copy Storage File Or Other Shadow Copy Data (0x8004231F)" !!!
2023-11-25T04:30:16+00:00 -
2023-11-25T04:31:13+00:00 Unless you share the Acronis report file on OneDrive or a similar host, I won't be able to help.
2023-11-25T04:42:38+00:00 2023-11-24 22:39:55 GMT-06:00
AcronisVSSDoctor-net45, 1.1.53.0, v4.0.30319
Microsoft Windows NT 6.2.9200.0, 4.0.30319.42000
VSS Services Configuration and Status
Status: OK
Description: All VSS-related services are configured correctly
Services:
Title: Microsoft Software Shadow Copy Provider
Status: Stopped
ReferenceStatus:
NeedToFixStatus: False
StartMode: Manual
ReferenceStartMode: Manual
NeedToFixStartMode: False
IsOk: True
ExpectationDescription:
Exception:
Title: Volume Shadow Copy
Status: Stopped
ReferenceStatus:
StartMode: Manual
IsOk: True
Exception:
Title: COM+ Event System
Status: Running
ReferenceStatus: Running
StartMode: Auto
ReferenceStartMode: Auto
IsOk: True
Exception:
VSS Access Control Configuration
Status: OK
Description: Known VSS access control entries are configured correctly
AccessControls:
UserName: NT Authority\NetworkService
EntryExists: True
UserExists: True
IsActive: True
IsOk: True
StatusDescription:
VSS Components Availability
Status: OK
Description: VSS components are accessible
VSS Writers Status
Status: Warn
Description: Some VSS writers were failed. Event Log may contain more details.
Writers:
Name: Task Scheduler Writer
State: [1] Stable
IsOk: True
Error: No error
Name: VSS Metadata Store Writer
State: [1] Stable
IsOk: True
Error: No error
Name: Performance Counters Writer
State: [1] Stable
IsOk: True
Error: No error
State: [7] Failed
IsOk: False
Error: Timed out
State: [1] Stable
IsOk: True
Error: No error
Name: IIS Config Writer
State: [1] Stable
IsOk: True
Error: No error
Name: MSMQ Writer (MSMQ)
State: [1] Stable
IsOk: True
Error: No error
Name: Shadow Copy Optimization Writer
State: [1] Stable
IsOk: True
Error: No error
State: [7] Failed
IsOk: False
Error: Timed out
State: [1] Stable
IsOk: True
Error: No error
Name: IIS Metabase Writer
State: [1] Stable
IsOk: True
Error: No error
Name: MSSearch Service Writer
State: [7] Failed
IsOk: False
Error: Timed out
VSS Shadow Storages Status
Status: Warn
Description: Some VSS shadow storages are misconfigured
Storages:
ForVolume: C:\
OnVolume: C:\
Used: 0 B
Allocated: 0 B
Maximum: 5668 MB
Minimum: 320 MB
VolumeSize: 110 GB
Available: 32 GB
TargetMaximum: 11 GB
MaximumGreaterThenMinimum: True
MaximumIsEnough: False
MaximumIsNotReached: True
AvailableIsEnoughForMaximum: True
IsOk: False
Description: Recommended Maximum storage size is 10 percent of volume size
ForVolume: D:\
OnVolume: D:\
Used: 0 B
Allocated: 0 B
Maximum: 298 GB
Minimum: 320 MB
VolumeSize: 298 GB
Available: 322 MB
TargetMaximum: 29 GB
MaximumIsEnough: True
AvailableIsEnoughForMaximum: False
IsOk: False
Description: Available free space is not enough for configured Maximum. Clean up some space.
Disk Free Space Available
Status: Warn
Description: Some disks have insufficient free space. Perform a cleanup.
Volumes:
DeviceId: \?\Volume{82a8bf11-0000-0000-0000-402400000000}\
Available: 32 GB
Minimum: 320 MB
IsOk: True
Description:
IsMounted: True
DeviceId: \?\Volume{a172abcb-0000-0000-0000-100000000000}\
Available: 322 MB
Minimum: 320 MB
IsOk: True
Description:
IsMounted: True
DeviceId: \?\Volume{82a8bf11-0000-0000-0000-100000000000}\
Available: 127 MB
Minimum: 320 MB
IsOk: False
Description: Free space is below required minimum
IsMounted: False
DeviceId: \?\Volume{82a8bf11-0000-0000-0000-50d11b000000}\
Available: 76 MB
Minimum: 320 MB
IsOk: False
IsMounted: False
Disk I/O Load
Status: OK
Description: All disks are currently not overloaded
Disks:
DiskBytesPersec: 240160
DiskReadBytesPersec: 25713
DiskReadsPersec: 1
DiskTransfersPersec: 23
DiskWriteBytesPersec: 214446
DiskWritesPersec: 22
PercentDiskReadTime: 0
PercentDiskTime: 0
PercentDiskWriteTime: 0
PercentIdleTime: 98
IsOk: True
DiskBytesPersec: 0
DiskReadBytesPersec: 0
DiskReadsPersec: 0
DiskTransfersPersec: 0
DiskWriteBytesPersec: 0
DiskWritesPersec: 0
PercentDiskTime: 0
PercentIdleTime: 99
IsOk: True
NTFS Volume Access Control Configuration
Status: OK
Description: All volumes have correct access control configuration
Volumes:
SystemHasAccess: True
SystemSid: S-1-5-18
IsOk: True
Description: "SYSTEM" account has "Full Control" access
SystemSid: S-1-5-18
IsOk: True
SystemSid: S-1-5-18
IsOk: True
SystemSid: S-1-5-18
IsOk: True
Event Log
Status: OK
Description: No VSS-related errors or warnings during previous day
Events:
2023-11-25T04:54:01+00:00 The command recommended in that YouTube video should help.
Please use 6 GB instead of 12 GB as you don't have too much free space on the C drive.
- vssadmin resize shadowstorage /For=C: /On=C: /MaxSize=6GB
2023-11-25T05:07:24+00:00 Ok That Fixes That But Now How Do I Get To "Command Prompt Administrator" On Windows 10 ?
