Please run Acronis VSS Doctor [More Info] and click "Start diagnostic".
Once done, click "Save report".
Copy the contents of the report and post it here.
While Trying To Create A Restore Point In System Restore I Get The Following Error Message .
"The Restore Point Could Not Be Created For The Following Reason : Insufficient Storage Available To Create Either A Shadow Copy Storage File Or Other Shadow Copy Data (0x8004231F)" !!!
2023-11-21 23:56:39 GMT-06:00 AcronisVSSDoctor-net45, 1.1.53.0, v4.0.30319 Microsoft Windows NT 6.2.9200.0, 4.0.30319.42000 =========================================================== VSS Services Configuration and Status Status: OK Description: All VSS-related services are configured correctly Services: Name: swprv Title: Microsoft Software Shadow Copy Provider Status: Stopped ReferenceStatus: NeedToFixStatus: False StartMode: Manual ReferenceStartMode: Manual NeedToFixStartMode: False IsOk: True ExpectationDescription: Exception: Name: VSS Title: Volume Shadow Copy Status: Stopped ReferenceStatus: NeedToFixStatus: False StartMode: Manual ReferenceStartMode: Manual NeedToFixStartMode: False IsOk: True ExpectationDescription: Exception: Name: EventSystem Title: COM+ Event System Status: Running ReferenceStatus: Running NeedToFixStatus: False StartMode: Auto ReferenceStartMode: Auto NeedToFixStartMode: False IsOk: True ExpectationDescription: Exception: =========================================================== VSS Access Control Configuration Status: OK Description: Known VSS access control entries are configured correctly AccessControls: UserName: NT Authority\NetworkService EntryExists: True UserExists: True IsActive: True IsOk: True StatusDescription: =========================================================== VSS Components Availability Status: OK Description: VSS components are accessible =========================================================== VSS Writers Status Status: Warn Description: Some VSS writers were failed. Event Log may contain more details. Writers: Name: Task Scheduler Writer Id: {d61d61c8-d73a-4eee-8cdd-f6f9786b7124} State: [1] Stable IsOk: True Error: No error Name: VSS Metadata Store Writer Id: {75dfb225-e2e4-4d39-9ac9-ffaff65ddf06} State: [1] Stable IsOk: True Error: No error Name: Performance Counters Writer Id: {0bada1de-01a9-4625-8278-69e735f39dd2} State: [1] Stable IsOk: True Error: No error Name: System Writer Id: {e8132975-6f93-4464-a53e-1050253ae220} State: [7] Failed IsOk: False Error: Timed out Name: ASR Writer Id: {be000cbe-11fe-4426-9c58-531aa6355fc4} State: [1] Stable IsOk: True Error: No error Name: IIS Config Writer Id: {2a40fd15-dfca-4aa8-a654-1f8c654603f6} State: [1] Stable IsOk: True Error: No error Name: MSMQ Writer (MSMQ) Id: {7e47b561-971a-46e6-96b9-696eeaa53b2a} State: [1] Stable IsOk: True Error: No error Name: WMI Writer Id: {a6ad56c2-b509-4e6c-bb19-49d8f43532f0} State: [7] Failed IsOk: False Error: Timed out Name: Shadow Copy Optimization Writer Id: {4dc3bdd4-ab48-4d07-adb0-3bee2926fd7f} State: [1] Stable IsOk: True Error: No error Name: IIS Metabase Writer Id: {59b1f0cf-90ef-465f-9609-6ca8b2938366} State: [1] Stable IsOk: True Error: No error Name: Registry Writer Id: {afbab4a2-367d-4d15-a586-71dbb18f8485} State: [1] Stable IsOk: True Error: No error Name: MSSearch Service Writer Id: {cd3f2362-8bef-46c7-9181-d62844cdc0b2} State: [7] Failed IsOk: False Error: Timed out =========================================================== VSS Shadow Storages Status Status: Warn Description: Some VSS shadow storages are misconfigured Storages: ForVolume: C:\ OnVolume: C:\ Used: 0 B Allocated: 0 B Maximum: 5668 MB Minimum: 320 MB VolumeSize: 110 GB Available: 33 GB TargetMaximum: 11 GB MaximumGreaterThenMinimum: True MaximumIsEnough: False MaximumIsNotReached: True AvailableIsEnoughForMaximum: True IsOk: False Description: Recommended Maximum storage size is 10 percent of volume size ForVolume: D:\ OnVolume: D:\ Used: 0 B Allocated: 0 B Maximum: 298 GB Minimum: 320 MB VolumeSize: 298 GB Available: 322 MB TargetMaximum: 29 GB MaximumGreaterThenMinimum: True MaximumIsEnough: True MaximumIsNotReached: True AvailableIsEnoughForMaximum: False IsOk: False Description: Available free space is not enough for configured Maximum. Clean up some space. =========================================================== Disk Free Space Available Status: Warn Description: Some disks have insufficient free space. Perform a cleanup. Volumes: Name: C:\ DeviceId: \?\Volume{82a8bf11-0000-0000-0000-402400000000}\ Size: 110 GB Available: 33 GB Minimum: 320 MB IsOk: True Description: IsMounted: True Name: D:\ DeviceId: \?\Volume{a172abcb-0000-0000-0000-100000000000}\ Size: 298 GB Available: 322 MB Minimum: 320 MB IsOk: True Description: IsMounted: True Name: \?\Volume{82a8bf11-0000-0000-0000-100000000000}\ DeviceId: \?\Volume{82a8bf11-0000-0000-0000-100000000000}\ Size: 578 MB Available: 127 MB Minimum: 320 MB IsOk: False Description: Free space is below required minimum IsMounted: False Name: \?\Volume{82a8bf11-0000-0000-0000-50d11b000000}\ DeviceId: \?\Volume{82a8bf11-0000-0000-0000-50d11b000000}\ Size: 529 MB Available: 76 MB Minimum: 320 MB IsOk: False Description: Free space is below required minimum IsMounted: False =========================================================== Disk I/O Load Status: Warn Description: Some disks may be overloaded. VSS may behave incorrectly under such conditions. Stop heavy operations or wait until completion. Disks: Name: 0 C: DiskBytesPersec: 1637925 DiskReadBytesPersec: 1389065 DiskReadsPersec: 136 DiskTransfersPersec: 183 DiskWriteBytesPersec: 248859 DiskWritesPersec: 47 PercentDiskReadTime: 1 PercentDiskTime: 2 PercentDiskWriteTime: 0 PercentIdleTime: 94 IsOk: False Name: 1 D: DiskBytesPersec: 0 DiskReadBytesPersec: 0 DiskReadsPersec: 0 DiskTransfersPersec: 0 DiskWriteBytesPersec: 0 DiskWritesPersec: 0 PercentDiskReadTime: 0 PercentDiskTime: 0 PercentDiskWriteTime: 0 PercentIdleTime: 98 IsOk: True =========================================================== NTFS Volume Access Control Configuration Status: OK Description: All volumes have correct access control configuration Volumes: Name: C:\ SystemHasAccess: True SystemSid: S-1-5-18 IsOk: True Description: "SYSTEM" account has "Full Control" access Name: D:\ SystemHasAccess: True SystemSid: S-1-5-18 IsOk: True Description: "SYSTEM" account has "Full Control" access Name: \?\Volume{82a8bf11-0000-0000-0000-100000000000}\ SystemHasAccess: True SystemSid: S-1-5-18 IsOk: True Description: "SYSTEM" account has "Full Control" access Name: \?\Volume{82a8bf11-0000-0000-0000-50d11b000000}\ SystemHasAccess: True SystemSid: S-1-5-18 IsOk: True Description: "SYSTEM" account has "Full Control" access =========================================================== Event Log Status: Warn Description: Some VSS-related errors or warnings occurred during the previous day Events: Timestamp: 11/21/2023 9:50:56 PM Type: Error Source: volsnap Message: The shadow copies of volume C: were deleted because the shadow copy storage could not grow in time. Consider reducing the IO load on the system or choose a shadow copy storage volume that is not being shadow copied. InstanceId: -1073348583 SearchLink: https://www.google.com/#newwindow=1&q=volsnap+event+id+3221618713
The code formatting didn't help as you can see above.
Please share the file on OneDrive.
