leptop battery passantage is not increase...so ...what soluation
Power & battery settings in Windows 11 won't open
The power & battery settings won't open when going to Settings >System > power & battery. The same thing happens when I right click the battery icon (power & sleep settings) in the sys tray.
2025-03-25T06:25:26+00:00 -
2025-04-16T05:21:19+00:00 how to fix there are no power options available
2025-04-25T18:39:48+00:00 I am having issues with my laptop, even if its fully charged i can only use it for 2 hrs and later the battery brains so drastically that my laptop shuts down. if i charge it for 60% , i can only use it for 30min. Its been 4 years since i bought this laptop. should i change the battery or is there any chances for me to fix this issue??
2025-04-27T08:48:56+00:00 My 3-year-old laptop's battery isn't charging. It's been plugged in for 2 hours, but still shows 0% charge.
