Microsoft Edge is making Suspicious Connection?
2023-11-02T09:18:58+00:00
is Microsoft is making suspicious connection to this URL deff.nelreports.net/api/report?
Also let us know which data is being sent to this URL & When?
2023-11-15T15:40:03+00:00
*.nelreports.net is a Microsoft domain. Several certificates used on the subdomains of this domain expired last week.
There is no security impact or end-user-impact of the certificate expiration -- Basically, the browser will be unable to submit Network Error Logging reports until the certificate is corrected. Network Error Logging is a HTML5 feature to allow site owners to discover network connectivity problems. https://developer.mozilla.org/en-US/docs/Web/HTTP/Network\_Error\_Logging
Your security software is just announcing "Hey, this certificate is bad", a fact that the browser already was determining on its own, and to which it responds by not connecting to the server in question. The security software provides a redundant warning -- the browser will not use connections with expired or invalid certificates.
The subdomain names are random strings of characters with no particular meaning.
The relevant team has been notified about the certificate expiration and will correct the issue.
51 additional answers
    2023-11-11T02:40:14+00:00
    Same thing here. I was forced to end Edge through the task manager, as it runs in the background and Bit Defender issues the same alerts. "Suspicious connection blocked."
    2023-11-11T02:49:44+00:00
    I had the same suspicious alert. Looks like it's a MSFT owned domain
    What on earth is MSFT doing? It's also an awfully suspicious domain name
  3. _AW_ 69,496 Reputation points Volunteer Moderator
    2023-11-11T02:54:31+00:00
    It's a Microsoft registered domain -
    https://whois.domaintools.com/nelreports.net
    I can't tell you exactly what the connection is, but possibly SmartScreen related + Azure DNS
    Report it to Bitdefender as a potential false positive.
    Incorrect Detection: Report a false positive or false negative to Bitdefender
    2023-11-11T03:47:07+00:00
    Here is an excellent VirusTotal report on it...
    https://www.virustotal.com/gui/domain/deff.nelreports.net/details deff.nelreports.net
    Looks like that is a Microsoft URL that is invoked by Edge & Internet Explorer. The Google search (at VirusTotal) finds your query to be fifth down from the top of "about 177". It isn't happening to me. Maybe you've got an old certificate, I don't know. But when I look for mine, I find no certificate, in Manage Computer Certificates (type certificates into Search)...
    It also appears not to be mentioned in my firewall in outgoing or incoming rules, at "Windows Security, Firewall & Network Protection, Advanced Settings". Also, on that page, it isn't mentioned in "Allow an app through firewall".
    I read through a couple of those 177 but haven't found a cure for you. Maybe I'll try again later.
