Microsoft Edge is making Suspicious Connection?
2023-11-02T09:18:58+00:00
is Microsoft is making suspicious connection to this URL deff.nelreports.net/api/report?
Also let us know which data is being sent to this URL & When?
2023-11-15T15:40:03+00:00
*.nelreports.net is a Microsoft domain. Several certificates used on the subdomains of this domain expired last week.
There is no security impact or end-user-impact of the certificate expiration -- Basically, the browser will be unable to submit Network Error Logging reports until the certificate is corrected. Network Error Logging is a HTML5 feature to allow site owners to discover network connectivity problems. https://developer.mozilla.org/en-US/docs/Web/HTTP/Network\_Error\_Logging
Your security software is just announcing "Hey, this certificate is bad", a fact that the browser already was determining on its own, and to which it responds by not connecting to the server in question. The security software provides a redundant warning -- the browser will not use connections with expired or invalid certificates.
The subdomain names are random strings of characters with no particular meaning.
The relevant team has been notified about the certificate expiration and will correct the issue.
51 additional answers
    2023-11-13T18:13:32+00:00
    Facing same issue
    2023-11-14T10:43:00+00:00
    It is not false positive! The site does not have a valid certificate, so it could be redirected to a hacker site.
    Most probably it is not redirected anywhere, only the certificate is invalid as expired, but anyhow it should not be reported as false positive, the cert must be fixed.
    2023-11-14T12:54:26+00:00
    NO! If "deff.nelreports.net" and/or "bzib.nelreports.net" is/are malicious, "fixing" the certificate is completely WRONG. It should be inspected and deleted if necessary. That's a job for Microsoft.
    I have to trust Bitdefender's certificate check and refusal on the ground of invalidity.
    I have never seen either "deff.nelreports.net" or "bzib.nelreports.net" on this or any of my other computers so I presume it is malicious. I cannot determine whether Bitdefender's warning messages arise from access attempts by that website to the Edge software on this computer or a call from Edge to that website. I presume the former but do not know how to prevent its future success and damage if it obtains a valid certificate.
  4. Rob Koch 26,170 Reputation points Volunteer Moderator
    2023-11-14T19:04:12+00:00
    Read the entire thread Steven & Phober, there's a lot more known about this Microsoft MSN support website than you realize, so it really doesn't matter from a security sense that the certificate isn't up to date, since all of the sites involved are within Microsoft's control.
    That's not saying it's a false positive, but in truth, Bitdefender displaying this alert in this case is simply annoying the user and doing nothing to truly 'protect' you.
    In fact, from what I've seen, the simplest way to remove the problem is to simply turn off the MSN Newsfeed on the default New Tab settings in Microsoft Edge, since that's apparently where the article pages are that are calling these particular error reporting pages with the expired certificate. In other words, if the MSN News pages don't display, the errors also shouldn't occur, though I don't have Bitdefender to test and would never want it installed on my own devices.
    I've personally disabled the MSN Newsfeed and other default Microsoft start pages over 2 decades ago, since I prefer a simple About: Blank web page with no content as my own initial display, so I'd never see this issue in any case. I don't believe in vendor provided pages and instead prefer to choose my own, which provides true security and privacy.
    Rob
