Waiting for printer connection
2023-12-14T05:51:25+00:00
“Waiting for printer connection” pop up started coming up a couple of weeks ago and has been causing multiple issues.
Excel and Word randomly do not open, and then when I open the program again it tells me the file is already in use yet nothing is open. Task manager shows nothing open or running. I have to restart my computer each time to use the document or workbook and I sometimes I need to do this more than once before it will decide to randomly work.
I cannot print new documents or workbooks, it becomes unresponsive and then the program has to close. I can only print from saved documents, which o can’t always open!
MYOB cannot print now, I have to save as a pdf and then print. I know MYOB isn’t “Microsoft” but this only started when this pop up started. I have never experienced this issue before.
This is happening on all four computers and started at the exact same time.
I have tried turning off all network sharing connections and still no change.
This is really impacting my day to day operations ans these programs are all I use. It causing a significant loss of time.
Can someone please help?
    2025-03-31T14:03:23+00:00
    I had this issue on a brand new laptop. Everything was quick except for printing. In my case, I have two HP printers as my primary printers and both had the same issue.
    1. I downloaded the HP Drivers rather than using the Windows Versions
    2. Changed the printers from IPP to TCP/IP ports
    Printing reverted to quick without the wait. After replicating it on both printers, it may have just required step 2 but I don't have another printer to test with.
    2025-04-12T05:21:43+00:00
    I can print from my phone but somehow the printer will not work when I push the print button and "waiting for printer connection" message pops up.
