Ctrl + D is not working but Ctrl + R does (Excel or MS Project)
2023-12-12T07:09:24+00:00
Ctrl + D is not working, however all other short cuts are including Ctrl + R. I have latest excel version. Yesterday the function was working and today it doesnt work in excel or in MS Project. I have explored all the options i could find online and in this community group. i have used the onscreen keyboard without success. Its not a dirty keyboard or anything like that. the D works.
2023-12-19T19:44:01+00:00
From Windows Start Menu Open WebEx App.
Click On settings Option.
Navigate to
Keyboard Shortcuts  - In search menu type D – From List  - Uncheck Decline call option.
click on save.
Go back to MS Office apps and verify.
You > Nail > Head
This solves the problem.
2023-12-20T14:51:29+00:00
That helped! Love you, I'm addicted at shotcut Ctrl+D.
2023-12-21T05:31:02+00:00
Hi Nathan,
I was able to solve it by disabling the Ctrl + d keyboard shortcut in Webex.
Webex was my issue as well. Thank you! No idea why the app chose to enable the keyboard shortcuts when they had not previously been utilized.
2023-12-20T01:25:27+00:00
Hi Nathan,
This is the way. Thanks Arjan!
2023-12-19T20:05:40+00:00
This fixed it for me! In Webex it's under Settings, Keyboard Shortcuts, Meetings & Calls
36 additional answers
    2024-06-08T19:23:45+00:00
    That's not a solution - that resets ALL customizations.
