The previous system shutdown was unexpected
2023-12-10T09:27:12+00:00
I keep getting consistent bsod
This is what I found in event log
I have tried:
  • check, scan, restore health & scansfx in cmd and found no corrupt files
  • Doing full scan of the microsoft safety scanner and nothing wrong, too
  • Download win11 ISO: my PC can't run the setup & this event pop up:
Faulting application name: SetupHost.exe, version: 10.0.22621.1, time stamp: 0xdac8cfb7
Faulting module name: ntdll.dll, version: 10.0.22621.2506, time stamp: 0xbced4b82
Exception code: 0xc00000f0
Fault offset: 0x000000000010c7a9
Faulting process id: 0x0x478
Faulting application start time: 0x0x1DA2B394B43FAB2
Faulting application path: C:$WINDOWS.~BT\Sources\SetupHost.exe
Faulting module path: C:\WINDOWS\SYSTEM32\ntdll.dll
Report Id: ea0b57e0-023d-4f07-9621-91d1a92248e9
Faulting package full name:
Faulting package-relative application ID:
Is there any other way for me to fix this problem?
    2023-12-11T10:47:48+00:00
    Omg, it is only pass 1 and it found 700 error
  2. DaveM121 936.1K Reputation points Independent Advisor
    2023-12-11T10:52:33+00:00
    You can stop that scan, that does indicate the system crashes are caused by your RAM, it will need to be replaced.
    2023-12-11T10:55:42+00:00
    ImageThis is the last result
    1000 errors, do you know the cause for this?
  4. DaveM121 936.1K Reputation points Independent Advisor
    2023-12-11T10:58:46+00:00
    Those errors indicate your RAM has a hardware issue, it is not a software problem that can be fixed, the RAM needs to be replaced.
    2023-12-11T11:01:40+00:00
    Copy that, I will go to the acer store tomorrow.
    My question is, do you what cause my Ram to get errors? Malware? Or I misclicked anything?
