help how to change default .exe regedit
2024-02-13T03:32:57+00:00
so i just running .exe regedit from this website https://www.tenforums.com/tutorials/8703-restore-default-file-type-associations-windows-10-a.html the file format is exe.reg ,after running this , ican't run scrcpy (android screen to windows) please help
_AW_ 69,496 Reputation points Volunteer Moderator
2024-02-14T00:43:27+00:00
i don't think i have malware ,
You definitely do.
i get it why you said i have malware ,when i check the log file there is svchost.exe with discord logo and explorer.exe with also discord logo,
You likely ran a bundled Discord/malware installer that threw a fake error message.
  • Download Fixlist.txt **** and save to the folder FRST64.exe is in
  • Run FRST and press "Fix" - the computer will restart to complete the fix
Please upload Fixlog.txt
55 additional answers
    2024-02-13T13:03:09+00:00
    i swear before i run exe.reg and restart pc to make it work , scrcpy is just working fine ,if you ask why then i run exe.reg well because im trying install discord when i click the discordsetup.exe its show "how do you want open this file" thats why i google and found https://www.tenforums.com/tutorials/8703-restore-default-file-type-associations-windows-10-a.html this web,then i tried exe.reg from that website, but weirdly after restart my pc to make exe.reg work ,discord app somehow already installed lol ,i think i don't need exe.reg to fix discord install work even "how do you want open this file" this problem showing
    since then scrcpy not working anymore like the video i share ,it open new cmd tab then closed immedily
  2. _AW_ 69,496 Reputation points Volunteer Moderator
    2024-02-13T13:14:54+00:00
    2024-02-13T13:20:32+00:00
    still the same :') i tried it before ,same like in my video opening new cmd tab then closed
  4. _AW_ 69,496 Reputation points Volunteer Moderator
    2024-02-13T13:35:00+00:00
    We probably need to get a Process Monitor capture to see what is happening.
    https://learn.microsoft.com/en-us/sysinternals/downloads/procmon
    Right click Procmon64.exe and run as administrator. The capture button is third from the left.
    • Start capturing, reproduce the problem. Stop capturing.
    • Press Ctrl + S, select All events under Events to save > save the log
    • Zip the log and share on your OneDrive or similar
    Share OneDrive files and folders - Microsoft Support
