help how to change default .exe regedit
2024-02-13T03:32:57+00:00
so i just running .exe regedit from this website https://www.tenforums.com/tutorials/8703-restore-default-file-type-associations-windows-10-a.html the file format is exe.reg ,after running this , ican't run scrcpy (android screen to windows) please help
_AW_ 69,496 Reputation points Volunteer Moderator
2024-02-14T00:43:27+00:00
i don't think i have malware ,
You definitely do.
i get it why you said i have malware ,when i check the log file there is svchost.exe with discord logo and explorer.exe with also discord logo,
You likely ran a bundled Discord/malware installer that threw a fake error message.
  • Download Fixlist.txt **** and save to the folder FRST64.exe is in
  • Run FRST and press "Fix" - the computer will restart to complete the fix
Please upload Fixlog.txt
55 additional answers
  1. Emmanuel Santana 40,200 Reputation points Independent Advisor
    2024-02-13T10:33:14+00:00
    Backup and delete the folder, not the exe folder. But delete the persistent handler.
    2024-02-13T10:42:44+00:00
    i delete persistenthandler in .exe and restart and tried run scrcpy again it still like in the video i share :(
  3. Emmanuel Santana 40,200 Reputation points Independent Advisor
    2024-02-13T10:51:28+00:00
    Got it, in this situation, consider reviewing the Reddit link I shared earlier. Essentially, you can explore and inquire on those forums, including Stack Overflow, since the problem seems unusual given the registry adjustments made. At this stage, there might be a direct issue with file associations.
    Also, did you happen to create a restore point?
    2024-02-13T11:05:45+00:00
    sadly i don't create restore point :( ,is there original value for what exe.reg in that site change to my registry? i will change it manually to original value if there is.
    Edition Windows 10 Pro
    Version 22H2
    Installed on ‎13/‎02/‎2024
    OS build 19045.3803
    Experience Windows Feature Experience Pack 1000.19053.1000.0
