help how to change default .exe regedit
2024-02-13T03:32:57+00:00
so i just running .exe regedit from this website https://www.tenforums.com/tutorials/8703-restore-default-file-type-associations-windows-10-a.html the file format is exe.reg ,after running this , ican't run scrcpy (android screen to windows) please help
_AW_ 69,496 Reputation points Volunteer Moderator
2024-02-14T00:43:27+00:00
i don't think i have malware ,
You definitely do.
i get it why you said i have malware ,when i check the log file there is svchost.exe with discord logo and explorer.exe with also discord logo,
You likely ran a bundled Discord/malware installer that threw a fake error message.
  • Download Fixlist.txt **** and save to the folder FRST64.exe is in
  • Run FRST and press "Fix" - the computer will restart to complete the fix
Please upload Fixlog.txt
55 additional answers
  1. Emmanuel Santana 40,200 Reputation points Independent Advisor
    2024-02-13T09:06:57+00:00
    It seems like the .reg file you ran might have altered the registry settings related to .exe files, which could potentially affect how executables are handled on your system. However, based on the content you provided, it's hard to pinpoint the exact change that might have caused the issue with running scrcpy.
    Do you by any chance have a backup of your registry?
    2024-02-13T09:02:48+00:00
    hello , so i just running exe.reg from that link the code inside exe.reg is : Windows Registry Editor Version 5.00 ; Created by: Shawn Brink ; http://www.tenforums.com ; Tutorial: http://www.tenforums.com/tutorials/8703-default-file-type-associations-restore-windows-10-a.html [-HKEY_CLASSES_ROOT.exe] [HKEY_CLASSES_ROOT.exe] @="exefile" "Content Type"="application/x-msdownload" [HKEY_CLASSES_ROOT.exe\PersistentHandler] @="{098f2470-bae0-11cd-b579-08002b30bfeb}" [HKEY_CLASSES_ROOT\exefile] @="Application" "EditFlags"=hex:38,07,00,00 "FriendlyTypeName"=hex(2):40,00,25,00,53,00,79,00,73,00,74,00,65,00,6d,00,52,\ 00,6f,00,6f,00,74,00,25,00,5c,00,53,00,79,00,73,00,74,00,65,00,6d,00,33,00,\ 32,00,5c,00,73,00,68,00,65,00,6c,00,6c,00,33,00,32,00,2e,00,64,00,6c,00,6c,\ 00,2c,00,2d,00,31,00,30,00,31,00,35,00,36,00,00,00 [HKEY_CLASSES_ROOT\exefile\DefaultIcon] @="%1" [-HKEY_CLASSES_ROOT\exefile\shell] [HKEY_CLASSES_ROOT\exefile\shell\open] "EditFlags"=hex:00,00,00,00 [HKEY_CLASSES_ROOT\exefile\shell\open\command] @=""%1" %*" "IsolatedCommand"=""%1" %*" [HKEY_CLASSES_ROOT\exefile\shell\runas] "HasLUAShield"="" [HKEY_CLASSES_ROOT\exefile\shell\runas\command] @=""%1" %*" "IsolatedCommand"=""%1" %*" [HKEY_CLASSES_ROOT\exefile\shell\runasuser] @="@shell32.dll,-50944" "Extended"="" "SuppressionPolicyEx"="{F211AA05-D4DF-4370-A2A0-9F19C09756A7}" [HKEY_CLASSES_ROOT\exefile\shell\runasuser\command] "DelegateExecute"="{ea72d00e-4960-42fa-ba92-7792a7944c1d}" [-HKEY_CLASSES_ROOT\exefile\shellex\ContextMenuHandlers] [HKEY_CLASSES_ROOT\exefile\shellex\ContextMenuHandlers] @="Compatibility" [HKEY_CLASSES_ROOT\exefile\shellex\ContextMenuHandlers\Compatibility] @="{1d27f844-3a1f-4410-85ac-14651078412d}" [HKEY_CLASSES_ROOT\exefile\shellex\ContextMenuHandlers\NvAppShExt] @="{A929C4CE-FD36-4270-B4F5-34ECAC5BD63C}" [HKEY_CLASSES_ROOT\exefile\shellex\ContextMenuHandlers\OpenGLShExt] @="{E97DEC16-A50D-49bb-AE24-CF682282E08D}" [HKEY_CLASSES_ROOT\exefile\shellex\ContextMenuHandlers\PintoStartScreen] @="{470C0EBD-5D73-4d58-9CED-E91E22E23282}" [HKEY_CLASSES_ROOT\exefile\shellex\DropHandler] @="{86C86720-42A0-1069-A2E8-08002B30309D}" [-HKEY_CLASSES_ROOT\SystemFileAssociations.exe] [HKEY_CLASSES_ROOT\SystemFileAssociations.exe] "FullDetails"="prop:System.PropGroup.Description;System.FileDescription;System.ItemTypeText;System.FileVersion;System.Software.ProductName;System.Software.ProductVersion;System.Copyright;*System.Category;*System.Comment;System.Size;System.DateModified;System.Language;*System.Trademarks;*System.OriginalFileName" "InfoTip"="prop:System.FileDescription;System.Company;System.FileVersion;System.DateCreated;System.Size" "TileInfo"="prop:System.FileDescription;System.Company;System.FileVersion;System.DateCreated;System.Size" [-HKEY_CURRENT_USER\SOFTWARE\Microsoft\Windows\CurrentVersion\Explorer\FileExts.exe] [-HKEY_CURRENT_USER\SOFTWARE\Microsoft\Windows\Roaming\OpenWith\FileExts.exe]
    after running this when i open scrcpy v2.1.1, i usually run scrcpy with terminal with code :
    scrcpy -w -S -m 1920 -b 4M --max-fps 90 --window-title "awaw" --disable-screensaver
    now it not running anymore it only show multiple cmd tab open then nothing happend, ican send video if you want
    please help!
  3. Emmanuel Santana 40,200 Reputation points Independent Advisor
    2024-02-13T06:50:43+00:00
    Hello, thank you for reaching out to the Microsoft Community. I am here to help and provide assistance with any questions or concerns you may have.
    Could you please let me know what you're trying to do? Usually, you would open the Registry Editor by pressing the Windows key + R and then typing "regedit."
    Can you elaborate on your goal? Thanks a lot.
