HOW DO I MAKE A PROGRAM OPEN ON A SPECIFIC MONITOR THAT I DESIGNATE EVERY TIME I WANT TO OPEN IT?
2024-02-15T00:34:12+00:00
This isn't a new question but I've seen it asked here for 15 years and 3 OS variants with no actual answer (you'd think this would be something to work on instead of obfuscating how to get to your control panel, file, and drive locations while trying to turn my +$3K pc into a sub $400, non-portable tablet with no touch screen).
HOW DO I MAKE A PROGRAM OPEN ON A SPECIFIC MONITOR EVERY TIME?
Note, the question is NOT how to move a program after you open it; it is NOT how to change primary display; it is NOT how to anything other the actual question asked as specifically as the question is. If there is no answer and Windows just isn't able to (and our programmers don't care to work on it) just say so.
I have an OLED gaming monitor that I paid more for than I would ever have wanted to pay for a monitor and would like it to last as long as possible. I would therefore like it not to be the primary display. I only use it for media and gaming. The problem is that windows doesn't let me choose secondary displays to open games and reverts half of the applications I open and move over back to the primary display. I can do this with some games but most default to only opening on the primary monitor. I have a good LCD monitor I use for productivity and streaming while playing games that I would like to remain my main display where most apps, and all non-media apps, are default opening. So far the only way I know to do it is to turn the OLED off unless I am using it. This solution is clunky and kind of like using a kitchen knife to sharpen pencils when a pencil sharpener is can be made.
So please don't answer this if you are going to give the same non-answers I've been reading while searching for an answer to this (going back 15 years btw, because someone really cares about the user experience). If you have a real answer please give it, again, even if it is "we don't have a way and don't care to make one."
Windows for home | Windows 11 | Display and graphics
    2024-08-01T22:37:49+00:00
    Nope, still doesn't work here, and I'm current with all updates.
    2024-08-02T01:38:49+00:00
    The solution you provide does not work 100% of the time. I have a couple apps that open on a secondary monitor no matter what., which is what I think much of this frustration is about. The inability to have particular apps open on particular monitors, consistently as well. Why is this so hard, or not accomplished by now? If it can be, that ok, but an explanation of why it can't be would be wonderful to learn.
    2024-08-02T01:41:49+00:00
    Adding my reply to the larger question:
    The solution you provide (Control Panel/Display commands) does not work 100% of the time. I have a couple apps that open on a secondary monitor no matter what, which is what I think much of this frustration is about.
    Why is this so hard, or not accomplished by now? If it can't be, that's ok, but an explanation of why it can't be would be wonderful to learn.
    2024-08-02T16:05:31+00:00
    Are you familiar with Auto Hot Key?
    "Launch apps and program on specific monitors" https://www.autohotkey.com/boards/viewtopic.php?style=7&t=61564
    Essentially:
    Create AHK script with custom hotkey to open specific folders and programs to specific monitor location(s).
    You can setup a script for one hot key to call multiple programs at once and or react a certain way when particular folder is opened.
    Also have AHK can bring apps to foreground for quick switching.
    I have AHK override some of unused F keys to bring Discord and notepad++ to foreground when pressing F5 and F8.
    Example of my daily use:
    Turn on PC
    Click bat file that starts multiple ahk scripts compiled to .exe.
    Hit button on "Koolertron One Handed Macro mini Mechanical Keyboard" which types hotkey I designated in AHK.
    Koolertron>button2>types: ALT+CNTRL+2
    Google chrome opens on monitor 2
    Koolertron>20>cntrl+1> opens firefox to specific website on display 1.
    2024-08-03T18:08:05+00:00
    This worked for me. Thanks.
