HOW DO I MAKE A PROGRAM OPEN ON A SPECIFIC MONITOR THAT I DESIGNATE EVERY TIME I WANT TO OPEN IT?
2024-02-15T00:34:12+00:00
This isn't a new question but I've seen it asked here for 15 years and 3 OS variants with no actual answer (you'd think this would be something to work on instead of obfuscating how to get to your control panel, file, and drive locations while trying to turn my +$3K pc into a sub $400, non-portable tablet with no touch screen).
HOW DO I MAKE A PROGRAM OPEN ON A SPECIFIC MONITOR EVERY TIME?
Note, the question is NOT how to move a program after you open it; it is NOT how to change primary display; it is NOT how to anything other the actual question asked as specifically as the question is. If there is no answer and Windows just isn't able to (and our programmers don't care to work on it) just say so.
I have an OLED gaming monitor that I paid more for than I would ever have wanted to pay for a monitor and would like it to last as long as possible. I would therefore like it not to be the primary display. I only use it for media and gaming. The problem is that windows doesn't let me choose secondary displays to open games and reverts half of the applications I open and move over back to the primary display. I can do this with some games but most default to only opening on the primary monitor. I have a good LCD monitor I use for productivity and streaming while playing games that I would like to remain my main display where most apps, and all non-media apps, are default opening. So far the only way I know to do it is to turn the OLED off unless I am using it. This solution is clunky and kind of like using a kitchen knife to sharpen pencils when a pencil sharpener is can be made.
So please don't answer this if you are going to give the same non-answers I've been reading while searching for an answer to this (going back 15 years btw, because someone really cares about the user experience). If you have a real answer please give it, again, even if it is "we don't have a way and don't care to make one."
Windows for home | Windows 11 | Display and graphics
    2025-05-09T02:43:43+00:00
    shortcut 4 is properties. from prperties find the target adress line
    2025-05-09T03:34:19+00:00
    Wow, this worked for me. Thank you. I'm just very curious as to why this works? What does this command entail?
    2025-06-18T13:56:56+00:00
    Dear ShawnZ,
    -screen:X is not a switch any app understands, this is very misleading.
    2025-06-19T15:20:16+00:00
    Hi! I would use Microsoft PowerToys - Workspaces! This lets you easily customize the workspace you want to automatically pull up, then also configure an shortcut for the desktop.
    2025-06-21T23:41:02+00:00
    I googled this kind of question and found a reddit post that helped me https://www.reddit.com/r/XPpen/comments/fepkkx/tutorial_how_to_set_programs_to_open_on_a/
