nvidia display settings missing
2024-02-15T05:08:08+00:00
nvidia control panel is missing display settings, in my laptop it only shows 3d settings and developer, please help thanks
    2024-06-25T00:31:08+00:00
    I have never replied to any of the forums before and I have been a PC user since year 2000 and have solved most of my issues myself but now dont have enough time to spend time playing with the system so, thanks man!!! my case was this and I dont know how it happened but the only reason I never went for AMD is Nvidia's control panel and specifically its display and video settings. Thanks a lot... Stay happy and stay blessed.
    2024-06-28T01:22:19+00:00
    missing display
    2024-07-13T17:12:16+00:00
    Hi! I'm now have the same problem too but can I ask a question? When I playing Valorant on my PC ( of course the display is missing) when I use "Alt+Tab" to reach the web outside and re-enter to my game it always has a error that I cant control my character ( the char is moving without using keyboad and i cant use my mouse to turn around or sth) but it's just within 2-3s, sometime it could be lag ( the mouse's movement is slowing down when Im try to hover any buttons). So it's because of missing display in nvidia ? P/s: I just installed my PC 2 days a go
    2024-07-21T08:41:10+00:00
    Clicked every button in the Panel already xD i dont understand it. Gonna reinstall everything tomorrow. 2:22 am here now. But thanks for the answer =)
    Just makesure your selected display mode are NVIDIA on NVIDIA control panel > 3D settings > manage display mode
    and the display setting will appear :)
    2024-07-21T14:08:35+00:00
    Any update ?
